Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Printers, Copiers, Scanners and other Imaging & Printing Devices
Old 12-31-2018, 05:50 PM   #21
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Cap. plague in Minolta DiMAGE Scan Elite 5400?
Originally Posted by josipk View Post
Does anybody recognize the characteristics of schottky diode 34 30 on the picture (red arrow)? How could I test it?
May be this diode is the solution of reversed polarity problem on Minolta DiMAGE Scan Elite 5400?
Is that diode shorted?
Old 12-31-2018, 10:15 PM   #22
stj
stj's Avatar
City & State: Europe
it could be a 6.2v zener
Old 01-03-2019, 03:51 PM   #23
josipk
City & State: Koper
My Country: Slovenia
Thank you, in the mean time I found the pdf in attach.
I could test it only on the circuit, on both directions is 0,035 V with diode tester VC303.
josipk is offline   Reply With Quote
Old 01-05-2019, 01:02 AM   #24
josipk
City & State: Koper
I've unsolded and tested it with VC303:
- diode test shows 195 (forward) and 1 (reverse)
- position 2000 k Ohm shows 106 (forward) and 932 (reverse) Ohm
Old 02-03-2019, 06:29 AM   #25
josipk
City & State: Koper
Minolta Dimage Scan Elite 5400, as said before in the posts inoperative because of accidentialy reversed polarity.
Does somebody have the same scanner with mechanical issue and with good electronic components? I'd buy it. I'd also buy only the main electronic plate of scanner.
Rgds, Josip
Old 03-05-2019, 11:36 AM   #26
josipk
City & State: Koper
Got scanner with good plate and now it works ok.
Old 06-09-2019, 10:02 PM   #27
robca
City & State: Kirkland, WA
I'm also trying to repair a Dimage Elite 5400 II (the new model, the one with a LED light not CFL)
I found a 7812 chip that looks like a 12V voltage regulator, but the output is only 2.2V, even when lifting the output from the PCB (I was checking to see if the problem was with the regulator or the circuit following it). See picture attached.
While I find strange that the scanner uses a 12V rail, I cannot see what else that SMD chip could be if not a 7812 voltage regulator. The right pins are connected to GND and +23V, and the output is a lower voltage (albeit the wrong one). I don't think any 78xx chip outputs 2.2V, and even if it were, would not be market 7812, methinks... still I'm concerned about just putting 12V on a board. Any idea?
If anyone reads this and happens to have time to open theirs, could you measure the voltage out from the 7812?
Also, I lost the Dimage scan CD. I do have the driver, just not the scanning software. And, yes, I know I can use VueScan, but it's an extra $90 and I want to try also the original software. Please ping me if you are willing to share a copy of the CD (upload to Onedrive or Google drive)
robca is offline   Reply With Quote
Old 06-12-2019, 03:47 PM   #28
robca
Answering my own post: after looking at a few similar CCD datasheets (couldn't find one that looked exactly like mine), I realized that most CCDs for scanners are indeed powered with 12V. Replacing the 7812 seems to solve all problem, luckily there doesn't seem to be lasting damage.
For what is worth, I'm pretty sure that 6 fast flashes / pulses / blinks of the LED on a Minolta DImage Scan Elite 5400 II mean that the firmware found a CCD imager issue during self test (that explains why it happens right after the LED is pulsed)
Adding here for posterity, just in case anyone else happens to search for the same problem in the future
I'm still looking for the original CD, btw, if anyone would be so kind to share
Old 06-19-2019, 12:16 PM   #29
BGUERBET
City & State: PARIS
My Country: FRANCE
Line Voltage: 240VAC 50Hz
Smile Re: Cap. plague in Minolta DiMAGE Scan Elite 5400?
Maybe you want this setup utility for Dimage Scan Elite 5400II
It doesn't work with Dimage 5400 (first version).
It works perfectly with Windows XP mode on Windows 7 64...
Glad if it can help you
Bertrand
BGUERBET is offline   Reply With Quote
Old 07-28-2019, 06:26 PM   #30
robca
Bertrand
Apologies, I see this only now. Thanks so much, really appreciated
In the end, though, I realized that the Konica Minolta website does indeed have the full set of utilities and the scanner program. The download was so small (~6 Mb) that I assumed it contained only the driver, but does include everything (ah, the good old times when a complete program could fit on a few floppy disks
I managed to scan ~2,700 slides with the original program, on the latest Windows 10 (just needs the right driver, but the Minolta driver is not a binary, simply a configuration for the Windows built in scanning interface). Amazing how well such an old XP program is working on Win10 X64
