Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 05-12-2019, 05:23 PM   #21
stj
stj's Avatar
City & State: Europe
Default Re: Cordless Soldering Iron - recommendations?
ts80 is about 20-30w i think - it has an internal boost convertor so i dont know the supply limits.
Old 05-12-2019, 08:27 PM   #22
redwire
City & State: Alberta
My Country: Canada
TS80 USB-C QC3.0 charge is apparently 9V 3A for 18W. You need a Quickcharge powerbank for that.
TS80 "Power Input: 3.6V-6.5V/3A, or 6.5V-9V/2A, or 9V-12V/1.5A ~ (QC 3.0)"
No boost-converter in TS80 teardown, the P-fet goes from +in to the tip and there is a step-down converter.
https://www.eevblog.com/2018/08/11/e...ng-iron-review around 16:45 the pcb is open.
redwire is offline   Reply With Quote
Old 05-14-2019, 01:42 PM   #23
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
It's all about how the heat is conducted to the tip, see eg EEVblog #1064
I would not say it's as good but in a comparison to my 80w Weller WSP80 soldering station the TS80 does not loose by much.
Put another way desoldering large caps on multilayer PCB's is not super easy with either of them.
However paired with my powerbank it sure beats it in portability: I use if for example on machines with soldered batteries:
Huge advantages in battery operation both in convenience but also in no risk shorting out a battery with a grounded iron...
Per Hansson is online now   Reply With Quote
Old 05-14-2019, 01:56 PM   #24
stj
stj's Avatar
just as well, with the cost of the cartridges!!
Old 05-26-2019, 02:42 PM   #25
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Originally Posted by kc8adu View Post
and have about 500 medical packs waiting to be stripped.
i love these.
they are max 2 years old and few if any cycles.
Where are you getting them from
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 05-28-2019, 01:07 AM   #26
redwire
My Country: Canada
I noticed some cordless T12 stations that use a power tool (slider) battery. $60 USD. Search for "T12 Slider Battery" on fleabay.
Versions available are Dewalt, Mikita, Milwaukee M18, Bosch 18V.
It's another way to go.
Old 05-28-2019, 10:43 AM   #27
stj
stj's Avatar
nice idea,
but it looks like they are still trying to offload all the old 900 series handles.
those are terrible - if the tip was any further from the handle you would need a picany rail to mount a scope!!
Old 06-02-2019, 11:38 AM   #28
sam_sam_sam
Here is the battery pack for a battery operated soldering iron
This unit cost $20.00 and very is hack and easy convert to power this soldering iron
Old 06-02-2019, 11:48 AM   #29
sam_sam_sam
Here is a picture of the setup that I come up with
All battery parts were bought at Lowe’s Store *
The USB charger converter $20.00 *
The battery 4amph $50.00 *
The battery charger $25.00 *
The soldering controller $13.00 * AliExpress
So for $103.00 I have a very good setup
I used a 5 amp re-set-able fuse going to the power cord
I still going to convert a ZD-915 soldering station and use the same USB converter housing to power this unit as well now that I found a 24 volt battery pack for fairly good price
One note I have seen a tear down ( on You Tube ) of this battery pack and they do use very good quality batteries in there battery pack
One other note what I like about this soldering controller is that when you do not touch the iron for a little while it goes into the sleep mode and if you still do not touch it goes into power down mode very important feature for it being used on battery power ( and very inconvenient if being you are powering it on a home outlet the power down mode)
File Type: jpg 48115C99-82C9-47E5-A092-D6A90DBC7957.jpg (126.8 KB, 18 views)
Old 06-02-2019, 01:22 PM   #30
sam_sam_sam
One final note I also ordered a 20 piece set of soldering iron tips for this soldering controller from AliExpress for $38.00
One final note on the power down mode the display still stays ON and as soon as you move it powers back ON and back to the set point
Old 06-15-2019, 07:35 PM   #31
sam_sam_sam
I tried the Ksger soldering iron controller on that Medical Grade Switching Power Supply
for some time and seems to not have any problems powering it and it works very well on battery power as well I have two different versions of this soldering controllers there are different things about each one that I like and some things I do like about them
Old 07-05-2019, 05:24 PM   #32
sam_sam_sam
Here is a photo of the other version of this soldering iron controller
This works a little bit different I have figured out how to go into the menu and set the sleep and shut down timers for how I want it to work on battery power
Quicko T12-942
I just love this version of this this soldering iron controller
I just have one complaint about it and that is that does not have the feature that when you turn the encoder switch to the left it put it into the sleep mode or the power down mode but I can live with it
That the Ksger model does have this feature but it is a pain to set the temperature you frist have to push the temperature encoder switch then you can change the temperature
But like said earlier I like and dislike some features on each one
But what I do like about both of them are the tips are that they are very easy to use and heat very well
File Type: jpeg 0C7F5C29-B26B-4CF9-B3EA-B5062319C85F.jpeg (307.4 KB, 7 views)
File Type: jpeg C21A08F1-FA3B-4329-8FAB-B19B8C6ADE00.jpeg (259.3 KB, 6 views)
Old 10-09-2019, 05:55 AM   #33
hunghoang
City & State: Rolling Meadows
My Country: United States
Hakko FX-901 is one option which is also easy-to-carry battery-powered soldering iron and cordless design that makes this iron very handy to use virtually anywhere. I recommended this for hobby handicrafts such as stationary models and radio-controlled models.
hunghoang is offline   Reply With Quote
