Old 11-21-2019, 01:49 AM   #1
kalilinux25
City & State: Zamboanga city Talisayan
My Country: Phillipines
Line Voltage: 220V 60Hz
Exclamation asus x550VB keeps on sleeping mode
Ive already disabled all sleep option on the laptop but sometimes it goes sleep
Those the memory could be the problem?
kalilinux25 is offline   Reply With Quote
Old 11-21-2019, 03:27 AM   #2
SMDFlea
Moderator
City & State: York
My Country: UK
Default Re: asus x550VB keeps on sleeping mode
Does it sleep after 30 minutes or at different times.
SMDFlea is offline   Reply With Quote
Old 11-22-2019, 01:29 AM   #3
kalilinux25
sometimes a 1min somethimes 30 min and sometimes after starting
Old 11-22-2019, 06:37 AM   #4
KvnTM
City & State: Arnstein, Bayern (Bavaria)
My Country: Germany
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Does it go into sleep or does it shut off completely ?
If it goes to sleep I highly suspect there is something wrong with the lid switch.
KvnTM is offline   Reply With Quote
Old 11-22-2019, 08:25 PM   #5
kalilinux25
Yes it shut off the you need to press the power to see its display again
I also think its the LID switch because if I jsut remove the power flex it will not sleep
Old 11-23-2019, 05:33 AM   #6
KvnTM
My Country: Germany
It would be important to know if the laptop does indeed shut off completely or go into hibernation/sleep.
The power led does usually "breathe" or blink when the laptop is hibernating or sleeping.
Plug the power flex back in and wiggle it a little while the laptop is on. You might also try flexing the boards a little. Maybe there's a broken solder joint somewhere. But don't bend the boards like crazy! That would cause more damage.
Old 11-24-2019, 11:52 PM   #7
kalilinux25
Thanks I think the problem was the TRANSISTOR around the powerbutton board i think its faulty
Old 11-25-2019, 01:33 AM   #8
RethoricalCheese
City & State: Tartu
My Country: Estonia
Yes, that is the lid switch.
RethoricalCheese is offline   Reply With Quote
Old 11-25-2019, 02:20 AM   #9
kalilinux25
[IMG][/IMG]
what type of trasnsitor to
Old 11-25-2019, 03:07 AM   #10
SMDFlea
Moderator
City & State: York
My Country: UK
Its a hall switch as rhetoricalcheese said. Get one from a donor ,any 3V one will do.
It might be this AH180N-WG-7 https://www.diodes.com/assets/Datasheets/AH180N.pdf
Old 11-30-2019, 03:32 AM   #11
kalilinux25
[QUOTE=SMDFlea;927388]Its a hall switch as rhetoricalcheese said. Get one from a donor ,any 3V one will do.
It might be this AH180N-WG-7 https://www.diodes.com/assets/Datasheets/AH180N.pdf[/QUOTE
can u give me some quivalenvalue sir
Badcaps.net Technical Forums © 2003 - 2019
