Old 11-22-2019, 01:41 PM   #1
tvdad
City & State: Beverly Hills, California
Smile Panasonic (TC-50LE64) LCD tv turn on bright then dims
Hello all badcaps!
New member here, thank you all for allowing me join this forum.
I have a pickle with my tv
The whole screen turns on with a bright blue background, then after around 10 secs or so, it dims to a dark/faint dark blue.
No logo/words on screen.
Any ideas as to what's causing this?
It's a Panasonic LCD tv, model number: TC-50LE64
Thanks!
tvdad is offline   Reply With Quote
Old 11-22-2019, 04:35 PM   #2
tvdad
Default Re: Panasonic (TC-50LE64) LCD tv turn on bright then dims
I don't see an option to edit my post, so I'mma just reply here.
I've went ahead and attached the picture of what the boards look like in case anyone needed/wanted it.
TXN-A1VJUUS - A-board/main board
TNPA5807 - Power board
C500E06E02A - LED DRIVER
V420HK1-CS5 - T-con
Old 11-22-2019, 05:15 PM   #3
nomoresonys
City & State: midwest
My Country: U.S.
Your zip code means you don't have to mess around with it, it's not worth possibly getting shocked, there are lethal voltages on the powerboards HOT side.
nomoresonys is offline   Reply With Quote
Old 11-22-2019, 05:17 PM   #4
tvdad
Originally Posted by nomoresonys View Post
Your zip code means you don't have to mess around with it, it's not worth possibly getting shocked, there are lethal voltages on the powerboard.
My zip code means I like to do/fix things myself. Sometimes with help of course (like you guys
Any ideas as to what's causing this? I'd just buy the replacement part(s), if possible, and install it.
Thanks.
Old 11-23-2019, 02:16 PM   #5
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
These Panasonics have a self test option in the menu. Run it. Check that the latest firmware is on it. Do a factory reset and see if that helps.
Old 11-23-2019, 02:58 PM   #6
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Can we see the pictures of the whole backside of the TV showing all the boards and how they are connected to each other?
