Set came in with Audio but no video/OSD. Backlights are lit. I can't see any video using a flashlight. I read somewhere where a blank screen could be a software upgrade problem but customer did not bring the remote to try a upgrade test. Surface mount fuses on the main board seem ok. Any ideas?
Sony KDL-50W800C
Re: Sony KDL-50W800C
Check for shorted caps on the panel boards. Probably no tcon on this model.
https://www.badcaps.net/forum/showth...hlight=40w600b
There sure is one on that SO FALSE ASSUMPTIONS ASIDE, dprit is that your tcon board??: https://www.electropartsonline.com/s...oard-unit.htmlLast edited by nomoresonys; 11-23-2019, 09:24 AM.
Upload good clear pictures of the whole backside of the TV so we can see shwoing the boards what we are dealing with.Never stop learning
I would check the resistance of the output side of the fuse with ref to Ground and als check the resistance of all MLC Caps first before putting in new fuse.Never stop learning
I put in a new fuse and disconnected the 2 ribbons going to the signal board/panel. The fuse did not blow but the Sony light at the bottom of the set blinked Red ( It never did that before). Then I took the fuse out and tried it again and as before I had backlights and a normal lit Sony light at the bottom of the set. I'm leaning to something wrong on the T-Con board.
Originally posted by dprit View PostI put in a new fuse and disconnected the 2 ribbons going to the signal board/panel. The fuse did not blow but the Sony light at the bottom of the set blinked Red ( It never did that before). Then I took the fuse out and tried it again and as before I had backlights and a normal lit Sony light at the bottom of the set. I'm leaning to something wrong on the T-Con board.Never stop learning
