Hello there!
First post, as I was recommended this board I didn't know and it looks like the perfect place let me say first that my knowledge of CRT's is pretty limited but I'm aware of their potential danger.
So the issue is I have a great hp D8911 19" CRT with an integrated VGA cable. Suddenly yesterday it started not displaying red color component on VGA (white became cyan, yellow became green, etc...). I of course tested it on another computer and problem was the same.
By wiggling the VGA cable at the back right out of the cover the picture would quickly come back, but always go back to losing red.
Today I've opened it, discharged the anode, paid attention not to touch anything, and only checked the VGA cable. Noticed it was a continuous cable that went through the chassis, the cable shield grounded to it, and continuing to a connector inside a metal shell at the bottom of the gun. As the cable was continuous it didn't make much sense for me that wiggling the cable outside the chassis would fix the issue, yet it did... as I saw no particular visible problem or damage, I did put the cover back on, tried again to see if it was miraculously gone but (as expected) the issue was the same.
I re-opened it, and this time unscrewed the cable chassis grounding, and took the whole cable out. Put the cover back on, tried again, and this time the picture was perfect, even when wiggling the cable...that's good enough right now but still a bit puzzling, so I'm turning to you guys to see if there is some sense to make out of this and if I could do anything to make sure it's fixed for good.
That's basically it..here are a few pictures to illustrate it:
https://imgur.com/a/qXPAEm1
This album contains a few pictures and a video of the issue. In the video, I'm wiggling the VGA cable right where my fingers are in the 3rd picture. When strongly pulling the cable to the right side the picture was fine, when I let it go back to its natural position the problem occurs.
This is what it looks like now, not showing any problem.
Thanks a lot in advance!
