HP Elitebook 840 G2
    Re: HP Elitebook 840 G2
    Thank you very much this forum is very helpful
      Re: HP Elitebook 840 G2: Flash BIOS to clean password
      Hi, I'm trying to write a new bios to a Hp Elite Book G2. I have a CH341A usb interface but I cannot write. It erases the chip in 1 sec but when i try to blank error straight.
      I'm using CH341A Programmer v1.34
      Any suggestions ?
        This is the error (Chip main memory are not null )
          use this program and remove the bios chip from the board before reading or writing.
          https://www.badcaps.net/forum/showpo...6&postcount=10
            Thank you, i will try today
              EliteBook 840 g2
              EliteBook 840 g2
              u365 is mx25l12873
              u366 is 26q16dvsig
              looking for good bios , i post my dump
                Re: EliteBook 840 g2
                Originally posted by lordgeny View Post
                EliteBook 840 g2
                u365 is mx25l12873
                u366 is 26q16dvsig
                try..
                  this are for bios ?
                    this are for bios ?
                    yes, just write the 16MB chip, the other one stays the same ..
                      Hello! please help, HP elitebook 840 G2,the machine starts, fan rotates at full speed and the screen is black,password lock .
                        Hi guys,
                        I am currently trying to get the BIOS dump for an Elitebook 840 from a CH341A + SOIC8 clip with AsProgrammer 1.4.1
                        I have identify 2 chips, a Macronix MX25L12873 and a WINBOND 25Q16DV
                        I saw in previous messages that the Macronix is the main BIOS chip. Can you confirm?
                        When I read this one, I obtain a 16Mb file but only FFFFFF in it.
                        The CMOS battery is still there. Should I remove it?
                        Any other suggestion? Thanks for you help
                        Grego
                          suggestion - https://www.badcaps.net/forum/showpo...6&postcount=51
                            Hi guys,
                            Question,
                            The bios from the site is 10 MB and the dump is 16 MB how to build a new bios? what do you have to lose from the old one? where to upload new to old?
                              Originally posted by alosm View Post
                              Hi guys,
                              Question,
                              try the bios from post # 64 ...
                                Originally posted by SMDFlea View Post
                                Thanks for the suggestion.
                                So I removed the battery, plugged the charger and turn on the laptop.
                                Screen remains black and fan turn at high speed
                                (same if I put back the battery)
                                Reading the chip still brings FFFF only
                                Should I try to erase the BIOS chip and replace by one such as the one post#64 or it is a bad idea?
                                  The machine starts, fan rotates at full speed and the screen is black
                                      post the motherboard model.
                                        I have such a message "Warning machine is not in committed state"
                                        System Board CT PEVMN00WB241HU
                                          I uploaded the file that I glued from the original one from the website + hp840g2_lock_12042021.bin, after uploading I have a message as above
