I am working on this 75" tv with backlight issues. I have removed the LCD and diffusers and and identified the strips/beads that need to be replaced/repaired.
The videos I reviewed about the teardown and testing of the backlights made it seem that they should separate easily. I am having difficulty removing the strip from the power and separating the individual strips.
For the power connection I see the white tab that must be lifted. It also looks like the two tabs under the blue plastic must be pressed down as well. I don't want to force any thing and break the connection. Is there a trick to getting it out?
The other picture is the strip connection. These don't separate just by pulling apart. Again, I don't want to break it. Do I just use a flat head to pry apart? Or is there a trick to this one as well?
