I'm working on a 820-2532-A and have found a short across C7252 (PP5V_S3_REG, 5V out). I introduced voltage across C7252 (using an external power supply) and only the cap felt hot. When I removed C7252 the short goes way. When I measure across the cap that is removed from the board it does not measure are hard short (low resistance) but when I apply voltage only across the cap it draws alot of current from an external power supply, so I know this cap is bad. I am trying to find a replacement for this shorted cap. On the 820-2532-A schematic it list the following info about this cap:
C7252 = 330uF, 20%, 6.3V, POLY-TANT, CASE-D3L-SM1.
I contacted Mouser and they couldn't find a match but did reply with
T520Y337M010ATE025 10V, 330uF, 20%, KEMET Tantaium Capacitors - Polymer
I would like to know thoughts
