hitachi 49HL15W69
    hitachi 49HL15W69
    hitachi 49HL15W69
    On t-con I have spi winbond 25q16dvig
    On mainboard I have spi 25L1606E and NAND MT 29F4G08ABAEA
    CPU is ARM MSD95PMVW4-4-0036 ATPS618A
    Panel is VES490QNUS-2D-U01
    When I turn TV on - TV starts backlight is ON but no image no logo no picture on the screen. On motherboard optical socket is glowing red. TV rensponce on remote I can turn on and off via remote
    I have searched internet looking for dump those spi`s and nand but no luck.
    I searched official site for looking for any kind of firmware but no luck.
    Maybe someone have dumps and wanna share with me
    Here are some pictures
    images t-con
    Re: hitachi 49HL15W69
    If you connect your PC does your PC recognise it is connected and can you send sound to the set.
      yes when i connect laptop via hdmi. Laptop recognises that I connected TV and is sending sound via hdmi but on TV I have no sound ( I think in TV is set on different source than hdmi and I cant change source because I have no picture on it)
        Check what dc voltage you have at each side of the smd component marked N which is a fuse.
          12v on each side
            Might be able to check for sound, maybe try hooking up a dvd player hit play on dvd player, then use your remote to toggle source on tv, one click give it bit, see if you hear sound if tv remote and sound is working, you should hear sound when it hits the proper hdmi or rca setting.
              yea I already tried that but I have only a hdmi cable. I was trying to change tv source via remote but no luck
                I measured voltages on t-con and I have:
                VCC F 3.3V - I have 3.3V
                Fuse is OK and have 12v on both sides
                VCC B 1.8V - I have 1.78V
                HVIN 12V - 0v
                VCC A 1.8V - I have 1.8V
                VCC 3.3V - I have - 3.3V
                VCC 1.05V - I have 1.17V
                VINI_12V - I have 12V
                AVDD - I have 0v
                HAVDD - I have 0v
                  Originally posted by hşzma
                  i have the same problem, any solution?
                  Same problem trying to get sound?
