Muskoka 35" curved fireplace power supply.
    Re: Muskoka 35" curved fireplace power supply.
    The relay is back in
    I checked D10 (2nd in attached ) and got a reading of .313. should i have take it off to get a true reading or is that ok?
    Also checked the fuse everything good there
    Readwire are you talking about the N next to the REALY1 (showed in attachment) and C5 also (Showed in attachment), and i need to test C5 while plucked up correct?
      Bumb
        So with everything connected back in place, what DC Voltage do you have when measured right between the two legs of two lytics filter caps in the HOT side? One is EC2, the other one I cannot see the whole disignator, EC?
        BTW, you will be working in the HOT deadly side so do not touch anything with your hands or body.
        https://www.badcaps.net/forum/attach...7&d=1551171961
          My Muskoka still not working. Some body try to bypass switching 12volts p.s. with a bulk p.s.?
          Regards,
            Just to make sure. It was the thermistor at the front of the blower!
            I completely forgot to report it. After 5 years I made it.
