Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
The controllers also do not work in Safe Mode. I understand that if they DID work in Safe Mode only then I might have a NOR Flash corruption, but that's not the case here. The controllers won't work in any mode.
Haven't encountered a problem quite like this before, so I am a bit unsure what to check. Was hoping you guys could help.
Thanks.
Thanks.
