convert a file .axe to Hex to load it in a pic 18f14k22
    Hello everyone
    I would like to ask you if you can convert a file.axe to Hex to load it in a pic 18f14k22.
    I'll explain better.
    I uploaded a file with .axe extension via an axe027 usb cable on this pic. the cable broke me I only have the pickit2 programmer and it does not load the .axe only Hex format.
    excuse me administrators I do not know if it was the right place to ask such a thing
    Re: convert a file .axe to Hex to load it in a pic 18f14k22
    there is at least something to read the information. I attach the file
      i think the pickaxe has a bootloader that loads the axe file, so it could be encrypted or incomplete without that bootloader.
      maybe Sonsivri knows more.
      http://www.sonsivri.to/forum/index.php
        unfortunately the site does not register. thanks for the reply
          the AXE file is not pic code, if you look in a hex editor you see a header and then a block of code that i suspect is tokenised or encrypted.
            in fact I had imagined it. thanks to all
              why not fix the cable?
                yes. I took another one
                unfortunately they are expensive
                  it's a usb to serial board with an ftdi chip and a custom id number
                  i dont think it needs to be ftdi,
                  and a lot of usb 2 serial boards from china for like €2 can either be fixed to show a different id or just patch the id in the software to match a standard cable
