Thermal camera IRepair RC 10 does not work.
  • caribert
    • Jul 2021
    • 14
    • France
    I bought from aliexpress a thermal camera IRepair RC 10 and it does not work.
    Under Windows 10 it is impossible to install the driver. Under Linux s VID:PID defined in the driver SeekWare.inf is unknown, but we get the name of the devices, visible spectrum camera, infrared spectrum camera.
    A hardware problem is most likely.
    In the datasheet of GL850G from Genesys logic ( HUB - Universal Serial Bus. ) it says QFN28/SSOP28 only supports 24C02.
    But instead we have a C06AB chip, datasheet not found.
    If you own this camera and have information about it you will be happy
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Thermal camera IRepair RC 10 does not work.
    Have you tried installing the camera driver with advanced startup option 7, disable driver signature enforcement?
    A working TV? How boring!
    • caribert
      • Jul 2021
      • 14
      • France
      Thank you for this answer.
      Yes, I have tried all the installation options, including disabling the signed driver. But without result.
      Here is a video of some of the tricks used to force the installation of the driver.
      I managed to install the driver by modifying the VID:PROD of the SeekWare.inf file by deceiving the installer with the vid-prod of the hub and apparently an unidentified device but probably the visible spectrum camera. But of course it did not work with the application.
        • Jul 2011
        • 6033
        Take a look at this website link page for the “GL850G”
        http://www.genesyslogic.com/en/product_view.php?show=21
        http://www.genesyslogic.com/en/product_list.php?1st=2
        I have a question for you did you buy at this website site link or did you buy it somewhere else
        https://www.fanscreate.com/products/...hermal-imaging
        If you bought it some where else it might be a clone
        One interesting thing I have not found any driver for this device
        But if you did buy it from the website site I that I posted email there customer support and see what they tell you about what drivers to use
        • caribert
          • Jul 2021
          • 14
          • France
          Here is the datasheet of the hub, I have studied it from top to bottom.
          https://pdf1.alldatasheet.com/datash...YS/GL850G.html
          For the driver here is the download site, no DVD provided. Site in http ???
          http://irepairbox.com/xzzx
          At this address we have photos of two different models, the IREPAIR RC10 and the Quianli (both Chinese) and I regret not having opted for the Quianli, but at the time of purchase it was much more expensive. The price has been lowered since replaced by a new model, much less efficient.
          "If you bought it elsewhere, it may be a clone."
          This is a serious hypothesis, indeed the technical choices are very surprising.
          The datasheet of GL850G (hub) indicates SSOP28 only supports 24C02 eeprom not present on the card, but we find a component totally unknown.
          I bought this product on AliExpress and the seller is phonefix. To avoid at all costs. Besides, any purchase of a too important value is to be considered with a lot of precautions. The camera was disassembled before sending and it is knowingly that they sent me a defective camera. The cost of a return is such that one hesitates to do it also the pseudo guarantee is an illusion.
          Since then I have changed the GL850G hub and the 100uF capacitor but without results.
            • Jul 2011
            • 6033
            Did you say that you received the device if you have not then file a complaint any way it might not do you any good but it is worth a try and would also try to get the right drivers and software to able maybe use it
            I have done this before file a complaint sometimes you get some where and sometimes you do not but you have lost much but a little bit of time
            https://litlesitegun.web.fc2.com/gl8...ub-driver.html
            Also look at this website page link this might help you might have to open the page a couple of times because of all the adds
            https://easysiteisland.weebly.com/bl...usb-hub-driver
              • Jul 2011
              • 6033
              I sent you a PM
              • caribert
                • Jul 2021
                • 14
                • France
                I have unfortunately validated the reception, despite a dispute from this reception for sending an expensive package without any protection. But in fact you should not validate the reception until you are sure that the product works properly.
                I asked for a refund which was refused.
                For the driver, the address above is the right one, it is on the head of the camera, IREPAIR RC10 and visible on the photos.
                I could not read the message in PM
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I don't understand, you take a photo of any damage, a video of it not working and if the vendor doesn't refund then Aliexpress do. Your item came with a 15 day free return.
                  • caribert
                    • Jul 2021
                    • 14
                    • France
                    I am happy for you that this is how it is for you, but in my case it was different. After information the cost of the reshipment was 190 dollars. I thought that this camera had cost me a lot of money, especially since I had no guarantee that an exchange would be better, given the lack of interest of the seller for an expensive and defective product.
                    • caribert
                      • Jul 2021
                      • 14
                      • France
                      I had put aside the fault finding, for having already spent too much time on it. By approaching the research differently I focused only on the thermal spectrum camera, indeed I thought at first that the management of the two flows was managed downstream but it is not the case. Detecting a short circuit of very low intensity I focused on the chip covered by a sticker and thermal paste and in grazing light I discovered a crack that turns out to be a fracture.
                      It is a microcontroller based on the Cortex-M4 of Arm, NXP LPC43S30FET100
                      The deterioration of this component is very easy to explain, by the very design of the heatsink excrescence of the package.
                      Looking at the datasheet of the microcontroller everything is explained.
                      Unfortunately this component is no longer available, except by ordering several hundred.
                      I will look for discarded materials, it has been used a lot in medicine and in the automotive industry, it seems.
                      I wonder about the programming of the component, I imagine that the installation of the driver records the necessary data.
                      I had started an application managing the two cameras, and we can find information on the management of the I2C protocol, but starting such a work to focus on a single use and now obsolete does not seem wise. I will study more carefully this project.
                      • gabiz_ro
                        • Mar 2011
                        • 167
                        • Romania
                        That GL850G may work fine without EEPROM.
                        C06AB is some voltage regulator,2.8V or 3.3V maybe.
                        Can you post some photo of damage?
                        You say LPC is cracked?
                        Those chips are pretty resistant vs PCB that is more fragile.
                        On that board there must be some SPI flash memory,by any chance can you read it and send me dump?
                        • lotas
                          • Jan 2016
                          • 4542
                          • Russia
                          C06AB (COxxx) - SY6280
                          • caribert
                            • Jul 2021
                            • 14
                            • France
                            Indeed the GL850G hub can be used without EEPROM, and this is the case for this camera, EEPROM that does not exist.
                            Most likely C06AB is a voltage regulator, 2.8V or 3.3V.
                            Some time ago and by awareness I had changed the component GL850G and the capacitor 100uF 16V, but without effect.
                            The manufacturer of the camera has integrated an infrared camera from SeekThermal and another normal spectrum camera by managing both video streams, on a USB output.
                            This makes the choices and understanding of the operation clearer.
                            For better quality photos and I will try to make a macro-photo of the cracked component.
                            These chips are very resistant, but the design of the heat sink is aberrant and is the sure cause of the damage. You can see a protrusion that goes through the motherboard and comes in direct contact with the component, damped only by a plastic sticker and thermal paste.
                            I have not located any SPI flash memory, but maybe new eyes will be able to do it, I will make a new series of pictures.
                            • gabiz_ro
                              • Mar 2011
                              • 167
                              • Romania
                              SPI i was talking about is on Seek camera module.Other side of PCB with LPC chip.
                              I can't see clear crack on LPC chip,seems to be some v mark scraped or something like a check mark symbol but seems huge.
                              edit
                              So you have two USB camera via a USB hub and no one works or get detected?
                              You may try to bypass USB hub and connect somehow direct to USB port and see if thermal and optical camera works.
                              • caribert
                                • Jul 2021
                                • 14
                                • France
                                Thanks for the link.
                                It is indeed more coherent.
                                • caribert
                                  • Jul 2021
                                  • 14
                                  • France
                                  edit
                                  The crack is very difficult to see, I have passed it many times under the microscope without seeing it.
                                  If you touch it with an instrument the corner moves.
                                  The normal spectrum camera works and is visible with the application provided here
                                  • gabiz_ro
                                    • Mar 2011
                                    • 167
                                    • Romania
                                    Then is gone.
                                    Another one.But out of stock everywhere.
                                    • caribert
                                      • Jul 2021
                                      • 14
                                      • France
                                      Then is gone.
                                      I will continue to look for this microcontroller ( NXP LPC43S30FET100 ), it's the only way to save this camera.
                                      • gabiz_ro
                                        • Mar 2011
                                        • 167
                                        • Romania
                                        If Mosaic Core (that is what Seek name that) follow their camera design you'll also need firmware for microcontroller.
                                        • bohaboha
                                          how to install gl usb2.0 uvc camera device driver on windows 10
                                          by bohaboha
                                          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                          any help?
                                          01-26-2025, 08:33 PM
                                          HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-06-2024, 06:20 AM
                                          HP EliteBook x360 1030 G2 + GoPro HERO6 Action Camera Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Action Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Action Camera boardview and 1030 G2 + GoPro HERO6 Action Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
