Samsung power supply BN44-00505A fault
    I have a problem with my Samsung TV. I was sitting watching TV when suddenly, the TV went bang. I changed the fuse in the plug-top, and it went bang again.
    I thought I'd have a look inside at the power supply. I found a couple of diodes that looked burned, so i replaced them. It turned out they were okay anyway.
    On closer inspection, I saw a capacitor was blown out. I replaced that and although it didn't go pop again, it also didn't work either.
    The capacitor I changed was CM804.
    Any ideas why this cap should blow? would it be something to do with the device ICM801S.
    Thanks.
    Re: Samsung power supply BN44-00505A fault
    Thanks.
    as per my experience, in most cases its the IC. why cap blows? age factor and dying parts. in your case, its the IC and the caps
