Bios for HP Prodesk 400 G2 Mini
    Re: Hp mini 400 g2
    Originally posted by bilen View Post
    DINO REV A : motherboard code
    problem no screen
    old bios :
    Can anyone help?
      Re: Hp mini 400 g2
      https://www.badcaps.net/forum/showth...ghlight=400+g2
        Re: Hp mini 400 g2
        I tried but it didn't work
          Re: Hp mini 400 g2
          thank you ıts working
            Re: Bios for HP Prodesk 400 G2 Mini
            hi, can any one fix this bios also plz. with n23 only fan spins..so plz fix this dump. thnx
              try..
                assalam o alikum sir build this file i have old orignal bios
                  post the old bios ..
                    Need help for Hp 400 G2 Mini bios
                    I have 3 Hp 400 G2 Mini pcs for repair. One pc was giving beeps without ram while other two were turning on with their fans spinning but there was no beep without ram. I copied and repaired there bios one by one but only the first one (giving beeps without ram) got fixed. I tried several times but other two didn't work. May be their bios is unrepairable for some reason. I know it's very difficult to repair these 6th Gen Hp Pcs without there original bios but is there any other way to fix/ repair them? I have attached the original files. Any kind of help will be greatly appreciated. Thanks.
                      Re: Need help for Hp 400 G2 Mini bios
                      No body
                        No reply
                          Originally posted by asb View Post
                          no reply
                          try..
                            Originally posted by peste View Post
                            try..
                            Hats off for PESTE . Problem solved
                              please help me . bios dump hp prodesk 400-g2 beep code 2 long 2 short
                                  Originally posted by SMDFlea View Post
                                  Try this one.
                                  EDIT: no pass
                                  Thanking you for this. Gotten a mini where the Unit would turn on with 5 white flashes and 1 red flash, not posting. The customer did his own programming and completely erased the bios. This file fixed it and we then updated from HP website. All is good now...
                                    try..
                                    Thank you, fixed my 400 G2 Mini also with this one. Added info, and works fine now. Wasn't booting at all.
                                      Tested and verified, just need to enter DMI data.
                                      I don't provide help for people using CH341A and a clip.
                                        nevermind, problem solved with the Bios-dump above
                                        Manymany Thx
                                          Manymany Thx
                                          HP ProDesk 400 G2 Desktop Mini PC
                                          Serial : CZC625BQTF
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
