Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 09-25-2021, 05:10 AM   #61
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Catapillar ECU repair, need N548AB replacement?
I'm half asleep but that didn't look much like a transistor. It doesn't seem to have a company logo either??
It looks like a hunk of metal.
I wonder if the device is actually a heatsink to help cool the board?
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 09-25-2021, 05:11 AM   #62
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
CapLeaker
But the question is have we figured out what type of device this is
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 09-25-2021, 06:50 AM   #63
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
thats a fucking fake!!
take a blade and scrape the resin away between the outer pins - it's gonna reveal a bus-bar!!!
stj is offline   Reply With Quote
Old 09-25-2021, 06:51 AM   #64
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Look at my first post. It is clearly a fairchild device. It's heat sinked to the casing, not to the board.
Quote:
Originally Posted by sam_sam_sam View Post
CapLeaker
To me a regular PNP / NPN transistor does not make any sense at all. More plausible is either a diode in disguise or a mosfet of some sort.
Haven't tried this yet, but lets say it is a mosfet. What happens if the gate isn't hooked up. There are actually schematics for other things that do show a mosfet with a floating gate. Most sense as of today in my mind in my particular case is a mosfet with a body diode and use it as a reverse fuse. Basically if something happens it will conduct drain and source pins and throw this way an error. Question here is: WHY are there 2 of them in parallel? At least it's not a dummy device with a jumper built in.
If I put my DMM in Ohms, put my negative probe at the source pin and the positive probe to the positive side of cap C2, I get close to 600k resistance.
CapLeaker is offline   Reply With Quote
Old 09-25-2021, 06:58 AM   #65
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
problem is the short was between the middle pin and one outer pin! Still scraping away... man... this stuff is hard!
edit: I gave up scraping. However I did put the decapped bottom part with the middle pin under a microscope and it does reveal a little solder blob like substance sticking to the metal. I looked on at the other half top part and sure there is a tiny pinhole in the whatever this plastic is made out of. To me, that is blown Drain Source pins.
You look at my post #60, second picture... you can see it.
Old 09-25-2021, 09:08 AM   #66
stj
stj's Avatar
but you have no silicon wafer - there is no semiconductor on the heatsink - never was!!
Old 09-25-2021, 10:15 AM   #67
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
How thick is the metal portion in the "heatsink" portion?
Not familiar with TO247AC construction since it was meant to be isolating, but a TO220 and TO3P the die is bonded straight to the heatsink pad which is really thick compared to the pin... so it can conduct heat away from the die.
What I'm seeing is that the heatsink pad is ... really thin? Thin enough so that it can actually be torn?
Die should be soldered to the heatsink pad, decapsulation usually damages die bonds. Also centered to reduce thermal resistance...
As much damage as it's taken now, is D-S still shorted?
eccerr0r is online now   Reply With Quote
Old 09-25-2021, 10:37 AM   #68
sam_sam_sam
My Country: USA
It would be interesting to find out what is this device because things are not adding up to exactly what this device is
Old 09-25-2021, 11:48 AM   #69
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
oh wait, well at least I'm not the only one who hasn't fully awakened yet... of course it's not going to conduct
The photos are convincing to me now, SHorT.
Old 09-25-2021, 02:52 PM   #70
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
The heat sink part is thick and really heavy compared to the top part. I am talking 1.6 gram vs 4.0 grams.O.k. put it this way: the short was between the middle pin 2 and the last pin 3. Something definitely went sour inside on pin 3 and blew through that plastic and shorted out to the heat sink part on pin 2.
No kidding... that's why I put it here. A mystery device and a weird circuit. Couldn't pass that.
Maybe I'll put that top part on my belt sander and see what that does.
Old 09-25-2021, 02:55 PM   #71
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Sadly I have to agree here.
Old 09-25-2021, 03:36 PM   #72
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Quote:
Or as I postulated early on, it was welded that way to begin with!
If it was a diebond that shorted through a die... it sure would not have separated like that, diebonds are physically weak and the die soldered to the metal would hold on, and you will get the die remnants.
So yes, you got SHorT dummy device here and need to look elsewhere for issues, perhaps that other device that connects to these dummies -- is that shorted?
Old 09-25-2021, 05:06 PM   #73
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Why make such a device for a dummy short. Much cheaper to put a piece of wire in!
Old 09-25-2021, 06:05 PM   #74
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
usually, mechanical/assembly reasons
You do realize there are 0 ohm resistors out there, full ceramic resistors that have a single black line on it... why use it when a bare wire works...
Just that when they have multiple SKUs using the same PCB it's easier to replace different parts than retooling the pick and place with jumpers.
Old 09-25-2021, 06:27 PM   #75
Agent24
I see dead caps
Agent24's Avatar
Oh I must have missed that.
It could possibly be designed to draw heat up the pins and dissipate out through the back plate?
I've seen mini heatsinks on a slot A motherboard that were soldered to the board.
Old 09-26-2021, 03:46 AM   #76
stj
stj's Avatar
it's probably to make it seem unrepairable.
now wouldnt it be funny if you found them in aliexpress - "surplus" from the manufacturing plant!!
Old 09-26-2021, 04:02 AM   #77
sam_sam_sam
My Country: USA
This might be reason that you could not find any information about the part number if it is that it is just a jumper
And
STJ
Might be right that they want you to think that it is not repairable
Old 09-26-2021, 09:02 PM   #78
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
You know, they probably did sell "surplus" TO247SHT's... easiest device to make fakes of...
but then people noticed they were dead from the get go and refunded all of them...
Wasn't worth it.
Old 09-26-2021, 09:16 PM   #79
stj
stj's Avatar
not fakes, i mean "recycled" / "re-directed" from the official production.
it happens a lot,
smd stuff is on reels of 500-5000,
they dont wait for the reels to run out before swapping them - where do you think the short reels of a few dozen to a few hundred parts go? in the trash? LOL
there is a shopping plaza in shenzen 10 floors high - nothing but component sellers.
i'm sure it's not a coincidence that it's in the same region as all the production companies!
Old 09-27-2021, 12:47 AM   #80
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Just saying, it's just as easy to make fakes and even cheap chinese knockoffs would work as good or even better than the original at much lower cost!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
