Lenovo V310-15IKB please bios
    Re: Lenovo V310-15IKB please bios
    Originally posted by dspok View Post
    Problem: Random no display
    Lenovo V130-15IKB 81HN
    SL R90V3KLD
    Can anyone extract original BIOS for me plz?
    Try and give feedback
      Re: Clear me region for this bios
      Originally posted by peste View Post
      try...
      thankyou so much
        this bios works well only delays at the start,anyone can repair it and post it here?
          Lenovo V310-15IKB - Bios
          Hi to all,
          After bios update from windows, laptop won't boot at all (just black screen and lights are on).
          Here is bios dump file from my laptop. If someone could give me correct bios version, I would appreciate
          Laptop info:
          Lenovo V310-15IKB
          Model: 80T3
          SN: LR08LDPN
          Factory ID: CS20
          M0: LRNXB732501J
          Mfg Date: 2017/3/05
          MTM: 80T3000K3YA
            Re: Lenovo V310-15IKB - Bios
            Try
              Originally posted by lapfix View Post
              Try
              Thank you lapfix, it worked
              Only one small issue with slow bios boot time, but it's better than not having boot at all
                If can help here ist mine,tested from working MB,100% ok
                  Hello friends
                  mine lenovo is dead after oficial bios upgrade...
                  need to relive
                  Lenovo V310 - 15ikb
                  Model 80T3
                  SN: LR076VMF
                  MO: LRNXB6C2400X
                  MFG Date 20/16/24
                  MTM 80T300EHCK
                  i tryed some dmps from web but nothing works
                  mine eeprom after bios upgrade is in attachment.
                  Thanx for help
                    Originally posted by jordiksvk View Post
                    hello friends
                    Need to relive
                    lenovo v310 - 15ikb
                    model 80t3
                    sn: Lr076vmf
                    mo: Lrnxb6c2400x
                    mfg date 20/16/24
                    mtm 80t300ehck
                    Thanx for help
                    new build virgin bios + DMI injected
                      thanx,
                      it will be approx 8th mine try...
                      i will post result tomorrow after testing.
                        qayyum786 - result not works at me....
                        lapfix - i tryed your dump upper, not works at me,
                        please could you help me
                        please modify mine dump what i posted?
                        thanx
                          Hello!
                          My laptop - Lenovo V310-15lkb,
                          SN: LR08GMYD
                          cannot start after bios update, i tried to press everything, novo button, fn buttons, power button, but nothing helps. Screen is black but I can hear the laptop running and the power button is lighten up.
                          Please help, I don't know what to do...I'm not a professionalist.
                            Originally posted by muniii View Post
                            Hello!
                            SN: LR08GMYD
                            Try some of the recovery options in this thread first - https://forums.lenovo.com/t5/Lenovo-...page=6#5180130 .If you have no luck then you will need to take the laptop apart and buy an SPI bios programmer,if you want to try programming the bios for yourself.If you don`t think you can do it,take it to a repair shop.
                            EDIT: Attached is the bios.cap file.Extract it from the zip folder and follow the instructions at the lenovo forum.
                              please could smbdy help me coorrect mine bios file?
                              thanx wery much. mine laptop is dead from april....
                                i tryed many dumps ower web,
                                have i damaged board?
                                or bad dumps me tryed?
                                can smbdy correct mine dump for testing ?
                                thanx wery much
                                this forum is mine only chance to relive laptop....
                                if not helped must buy new one....
                                thanx wery much.
                                  thanx wery much
                                  thanx wery much.
                                  Try this one .
                                    i have original beeprog programmer its professional.... i am using this daily for other chips programming....
                                    thanx for help, thanx for file i will try and give you result....
                                    god bless you
                                      outimage not works at me.
                                      maybe i have bad fuses set ?
                                      how to set fuses for programming flash?
                                      thanx
                                        thanx
                                        You don`t have to set any fuses. Check the traces,most likely damaged or the problem is somewhere else
                                          try...
                                          Too many thanks, works perfect
                                          MX25L12805 backupbbb.rar
                                          DA0LV6MB6F0 rev: f
                                          lenovo v510-15lkb 80WQ
                                          LV6 AND W25Q128FV
                                          AMD Graphics and intel i7
