LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Worked for a T560, thank you!
    (I needed a looong time to detect a loose connection / cable break at the test clip that caused unreliable results, but finally...)
      Hi, anyone can help with bios supervisor password with Lenovo thinkpad T14s with i7 10th gen ??
        im stuck.. i have 2 files.
        the T495 boots to the id and pass!
        but the universal patched boots F1 shuts off.
        while this one asks for id pwd.
        can this be patched to bypass w any pass ?
          pls any patcher for L460, L470?
            Patch for T495 (Amd Ryzen) i posted works with the generator from LBE !!
              hello.
              please can somebody help me to unlock and clean my bios from LENOVO X1 CARBON 8 TH Generation ?
              i dont know how to patch.
              thank you in advance.
                Originally posted by bogdan039 View Post
                hello.
                STEP 1: Flash and replace current BIOS with the generated patch file
                STEP 2: Boot the machine
                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                STEP 4: Enter any character when asked for Supervisor Password
                STEP 5: Press enter when it shows Hardware ID
                STEP 6: Press space bar 2x when asked
                STEP 7: Turn off machine
                STEP 8: Restore original BIOS
                STEP 9: Reset BIOS settings to factory defaulT
                  I have lenovo x260 it has a bios password, i have attached the backup file can somebody patch this up for me.
                  Regards
                    Regards
                      Thanks a lot, it worked, you are a Star.
                        There`s at least half a dozen patches already posted,try using the forum search next time
                        https://www.badcaps.net/forum/showpo...72&postcount=1
                        https://www.badcaps.net/forum/showpo...0&postcount=24
                        https://www.badcaps.net/forum/showpo...0&postcount=11
                          Originally posted by SMDFlea View Post
                          Apologies, I didn't know, I thought that the patch has to be created from the original bios of the laptop, next time I will try the patches available first.
                            no need to apologise for anything,just pointing out that its already been patched.
                              Will it work on Lenovo L570 7th gen?
                              Where is password in this model?
                                anyone has sugession about lenovo yoga x1 4th gen bios unlock
                                  Thank you very much.you are a genius, it works.
                                  After unlock bios it is bitlocker, i will try to format ssd or to replace it.
                                    Hi, can someone help me with this error, exporting the patched file?
                                    line 168, in patch
                                    os.rename('temp.bin', patched_filename)
                                    OSError: [WinError 17] O sistema não consegue mover o ficheiro para uma unidade de disco diferente: 'temp.bin' -> 'F:\\W25Q128FV_T450s_PATCHED.BIN'
                                      Lenovo t470s after flashing, pressing power button, no reaction, nothing...
                                      Need Help!!!
                                        Need Help!!!
                                        send dump file
                                          hi, when you guys say flash and replace the current bios do you guys mean you need to flash the bios using some external flashers? and not direct windows/software right? because i m confused as when you try to flash from within windows it doesnt flash if it has bios lock already. so i m assuming you guys are referring to some hardware flasher and some kind of soldering needed? is it correct?
                                          asking as a semi noob.
                                          thank you
