Lenovo Ideapad 3 NM-C821 - no display after fall
    Hello.
    Have this Lenovo Ideapad 3 NM-C821 that suffer fall from meter flatly, and after that have no display. I cannot check another lcd because lcd is glued to back and i dont have spare lcd cable. All voltages are OK.
    No video on HDMI and no activity on USB, only voltage. What can be bad?
    i was thinking about cracked ball under RAM or CPU
    or how to check video when have no display?
    Re: Lenovo Ideapad 3 NM-C821 - no display after fall
    no hint on this?
      i replace lcd so now im sure it is board problem.
      usb key dont even react and fan work normally
        Try to Reflow the Ram it may have loose contact due to fall.
          Cracked ball under bga chip is unlikley as lenovo uses glue beneath it. Problem may be elsewhere.
