Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 09-13-2021, 07:24 PM   #1
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Angry Dissolve heat conductive cement
WellÖ I am working on a Catapillar ECU (70 pin). I managed to take the main board on the top off after repeated prying, but how in the effin world does the driver board on the bottom come out? There is too much of that heat conductive cement on there. Itís hard almost like a rock. I guess it has a dual function, having thermal conductivity and keeping things planted due to vibration. Thought of putting Acetone in there, but then I donít know if any of the plastics are going to melt.
So how do I get that board heat conductive cement or whatever it is dissolved? Heat?
Old 09-14-2021, 02:38 AM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: Dissolve heat conductive cement
a long soak in petrol sometimes works . must admit i never tried that with the hard stuff .
Old 09-14-2021, 04:16 AM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
I think I may unsolder more stuff and see what that does.
Old 09-14-2021, 04:18 AM   #4
stj
stj's Avatar
City & State: Europe
the hard stuff if it's a blue-gray colour is epoxy resin loaded with zinc oxide.
good luck if it's that!!!
Old 09-14-2021, 10:18 AM   #5
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Yeah that stuff you are talking about is epoxy... This stuff here is very light grey and not that epoxy hard, but hard. I've unsoldered more, but still can't get that damn board off or out.
Old 09-14-2021, 11:06 AM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
thermoset plastics need to be banned so that we can repair our electronics...
(then again, IC encapsulation are thermosets...)
eccerr0r is offline   Reply With Quote
Old 09-14-2021, 03:17 PM   #7
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Well… I opened that ECU. See other thread.
Badcaps.net Technical Forums © 2003 - 2021
