Samsung Power Supply Board BN44-00150A
  • ikmpch
    • Jul 2020
    • 22
    There is a diode (DS 805) on the secondary side. Can anyone tell me what are the specs for this diode? It is a shotkey diode as the name tells it. Where to purchase it?
    Thanks.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Samsung Power Supply Board BN44-00150A
    what is written on the diode ?
    • R_J
      • Jun 2012
      • 9535
      DS805 is likely ok, it is across the relay coil. This is likely not the problem with the power supply. Post the problem you are having with the power supply.
      Post pictures of the board, it is likely bad capacitors in the secondary
      • ikmpch
        • Jul 2020
        • 22
        The diode seemed shorted so I tested the diode out of circuit and it was fine. Later I misplaced the little diode and can't find it so I have to get it's replacement. I guess it's a fast switching diode and operating voltage of 200 should be fine. Any comments?
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          1n4148 or similar for the snubber diode .
          • R_J
            • Jun 2012
            • 9535
            I suspect the original was a UF4007 based on a similar schematic
            • ikmpch
              • Jul 2020
              • 22
              Thanks Petehall347 and R_J for your help.
              • msh493
                • Nov 2021
                • 1
                Hi Folks, This power supply was making a clicking sound and taking a long time to start. I looked it up and apparently it's a buch of bad capacitors. There are 13 of them, all high temp, 4 of each of 47 mf, 1000 mf at 25v, and 1000 mf at 10v. I don't see any other caps or components suffering from heat. Is there anything else I should check before I start taking them out and replacing them? Thanks in advance for replies.
                  • Jul 2011
                  • 6033
                  I would recommend replacing all capacitors under 100uf in value because they have a tendency to dry out of electrolyte and cause all kinds of issues and if you have an ESR capacitor tester I would probably check all of the other capacitors on the switching power supply section of the board at a minimum
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Nicktronic
                    Samsung Power Supply Board BN44-00874F
                    by Nicktronic
                    Hey everyone,
                    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                    Anybody...
                    03-17-2025, 06:20 AM
                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                    by sam_sam_sam
                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                    Found shorted diodes on main controller relays there are 3 of them that...
                    01-07-2023, 05:43 PM
                    Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                    by sam_sam_sam
                    I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                    This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                    After all of...
                    07-13-2024, 08:14 PM
                  • repair-it
                    Need advice testing a samsung power supply board with scope
                    by repair-it
                    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                    07-12-2025, 11:00 AM
