Hello guys, I need some guidance to repair this board.
History
Board came to me after being inspected by another shop and declared dead. Previuosly water damage only in the ISL9240 area. Previous tech guy removed ic and make an horrible scratch game under it. By luck no pad were ripped off but nc ones. Then he soldered back U7000 on the up side down.
What I've Done so Far
I removed isl (u7000), clean and soldered back a new one. On my usb ammeter I had 20V so put motherboard back inside, assembled and macbook started. After a couple of minutes of testing i heard a click and macbook power off. I went to check motherboard, at this point usb ammeter didn't give any data. I found out PPDCIN_G£H_CHR_AMON was shorted to ground. I removed every single component on that line but the short was still there so I supected an internal line short. I rebuilt all the line outside of the board and put all component back from R7020 to U7000 pad. Line has 5V as it should but no switch to 20V on ammeter. PPBUS_G3H is cycling from 1.2V to 0.9V in a loop. LDO (3.3V and 1.5V) for bot CDs are present and stable. Just to be sure I changed U7000 again but still same behaviour. On ammeter I now have 5.2V 0.1A.
Any idea where to look?
History
