I'm new to this so please bear with me. I've been reading plenty of threads and so I'm hoping I've tracked down my issue.
My toshiba 24d1434db has no power, not even the standby led.
The capacitors all look OK and there doesn't appear to be an obvious blown component from looking at the board.
I've found threads for the Vestal boards which appear to indicate faulty diodes may be the issue.
I've tested with a multimeter and get the following readings:
D8 - no diode fitted
D9 (UF5402) - 0500 and 1000 when poles reversed
D10 (SB5B0) - 0030 and 0050 when poles reversed
D11 - no diode fitted
D12 (SB5B0) - 0030 and 0050 when poles reversed
D25 (SB5B0) - 0030 and 0050 when poles reversed
So I understand it's likely to be only one of the SB5B0 diodes but I'm best replacing them all. Can I fit a better diode? Any suggestions?
Should I replace the UF5402 diode as well or is that reading all ok and best left as is?
Can I fit extra diodes in D11 and D8 without any issues? (On one thread someone appeared to do this). Would this reduce the chance of a future re-occurrence as well as using thermal epoxy?
Thanks, your help is appreciated.
