LGLN575s-ZE backlight
    hello,I buy this tv with no backlight,ordered leds from ebay,change burned leds,
    tv power on with dark spots ,on screen,all led are working.
    tv is powered 5 minutes then shut down and no backlight again,leds burned again.
    what cause led to burn ?
    wrong leds ?
    Re: LGLN575s-ZE backlight
    Do you have the specification of the replacement LEDs?
    So the replacement LEDs failed again or the other original LEDs failed?
    We need more details and pictures.
      leds ---> LATWT470RELZK
      ordered from ebay ,ordered for 6916L-1214A backlight strip.
      will post pictures when I change leds
        Sounds like you did not replace all bad leds.
          OK burned leds are changed,with new.all were different big leds.
          now backlight not turning off and not burning
          but I have problem when I put filters back (look on picture).
            and changed led are little different colour
              What are those small black ring on the LED's LENS?
              https://www.badcaps.net/forum/attach...5&d=1498750427
              BTW, make sure to go into on screen setup and turn down the Backlights level (not Brightness) as low as possible, that will extend the life of the LEDs.
                I changed plastic led lens from another LG tv.
                  Those are not correct color. Also care must be taken to center lens over led
                    this is now my big problem
                      omg,yes now I need to take down lenses and center over led,and find what colour are original leds
                        ok what to use to glue led lens?it is very difficult to center lens.
                          I apply power to led. Makes it easy to center. Looking straight down no bright light coming out. I am still experimenting with glue
                            try flexible superglue
                              Locktite makes a supergel in a plastic bottle that you squeeze two blue side bars to dispense the glue. Also the old glue spots need scraped off smooth and the lenses put on level.
