Bios Password Dell Latitude 5510
    Re: Bios Password Dell Latitude 5510
    depending the size i choose
      @bacardi2001
      It doesn't work buddy, only with eeprom programmer, search for low cost eeprom programmer, type CH341A
        ok thanks
          Re: dell latitude 5510
          ok i just got the eeprom programmer, can you point me to a tutorial? thank you
            which chip is it? i don’t see one 25hq64
              found this chip qh256bxlq
                @bacardi2001
                Perfect! Read the chip
                  will do thank you. i’ll post it tomorrow
                    gonna try again
                      that chip isnt detected when i search for it with the software
                        is this the right chip?
                          Also which software reads that chip?
                            Can you manually select MX25QH256B ?
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              i will try, what software is that?
                                its not for the ch341a
                                  The CH341A will read it with NeoProgrammer software
                                    ok cool thanks
                                      i just keep getting…ic is not responding…i don’t even think the clip pins are touching the chip pins
                                        The chip type is WSON8,it has NO legs on it,so the SOP8 clip will not work. If you can desolder the chip you can get a cheapo adapter like this one https://www.aliexpress.com/item/32847804960.html
                                        If you can`t desolder it you will need to solder wires to the traces,or buy a WSON8 pogo adapter like this https://www.aliexpress.com/item/1005001830846980.html
                                          makes sense now, thank you
