Laser CNC, board MPC6515 driver panel PAD03 V1.2. In PAD03 V1.2 quartz resonator is broken. question - to what frequency was it. I try 12MHz but not succes.
Laser CNC
Re: Laser CNC
Originally posted by R_J View PostIt might be a mpc89e58, similar to a 8051, it should use a 12mHz crystal, Did you try an actual crystal or a ceramic resonator?
I will try another frequencies. I'm using now an 8MHz quartz resonator now, it shows the same message, but currently I don't have a communication checking machine. I will check on popular frequencies while in the company.Last edited by warsztat; 09-01-2022, 10:20 PM.
Re: Laser CNC
Check and see if it has a low voltage detection ic chip because some micro controller use this type of device and it will cause it to keep trying to restart in a loop
It would be located on the 5 volt rail near the micro controller input pin the device is normally a 3 pin device look at the data sheet for what would a low voltage detection circuitLast edited by sam_sam_sam; 09-02-2022, 04:43 AM.9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
