I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
Dead / No Power / No Standby Light results after power company had three
consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized the dump from it to rewrite the blanked EEPROM.
After replacing the restored IC1604 and mounting the Mainboard back into the chassis, the TV standby light illuminated. Then with a touch of the power button the Samsung 65" came back to life. Very Rewarding Experience I had to share with this Team. Hope this helps someone else with a similar issue and please see attached images for component location.
Good Luck and keep repairing and learning.
