This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It uses a tiny SOT transistor marked M7A. The only cross reference I found was a MMBT2907A. So I changed this transistor and the power supply came back to life. The 12 volt line measured 12 volts and the 5 volt line measured 5 volts. But the 3.3 volt line measured 2.36 volts. Looks like the transistor was bad but the replacement must not be the correct one. Help...can anyone find a proper cross reference for a SOT transistor marked M7A.
EVGA 500 watt with fan twitch
Re: EVGA 500 watt with fan twitch
My replacement MMBT2907A is marked 2F. I have checked the data sheet of several manufacturers and they all agree that the marking is 2F. Perhaps not all MMBT2907A transistors are equal???Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
I finally found MMBT2907A with M7A marking. It is made by Panjit. On Digikey and Mouser it is the cheapest MMBT2907A you can buy. Price is 8 cents apiece. What do you expect from a power supply made in China!Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
Ummmmmmmm high volume Delta power supplies are made in Dongguan, China. Probably the same with Lite On, Acbel, Fortron/Sparkle, and [u]Your Favorite Brand[/o] power supplies. The key factors are design quality, component selection, and employee retention (= keeping well trained people).PeteS in CA
Originally posted by PeteS in CA View PostUmmmmmmmm high volume Delta power supplies are made in Dongguan, China. Probably the same with Lite On, Acbel, Fortron/Sparkle, and [u]Your Favorite Brand[/o] power supplies. The key factors are design quality, component selection, and employee retention (= keeping well trained people).I'm not a expert, I'm just doing my best.
What does this switching power supply look like inside under the hood
Just curious about this9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
I installed a Panjit transistor marked M7A. End result was the same....2.4 volts on the 3.3 volt line. I replaced the 431 regulator chip. No change. I removed the two output caps and tested for esr. Both OK. Totally frustrated, I finally changed the tester I was using. Now everything measures ok. So it looks like I was chasing a ghost!
Conclusions: EVGA 500 watt power supply had a bad mag amp smt transistor. The transistors marked M7A and 2F are apparently interchangeable. The power supply is now in my garage powering an old KT7A motherboard and working fine. And finally, I hope I am not the only one who ocasionally goes chasing a ghost!Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
Found another EVGA 500 watt power supply with same symptoms. Replaced the 3.3 volt mag amp smt transistor. Original was marked M7A. Replaced it with a 2F. Power supply now works OK. Not sure if this is a design problem or just OEM using a POS M7A smt transistor.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
Originally posted by ChaosLegionnaire View Postu mean u are using a power supply tester? those are notoriously unreliable for testing and checking a power supply. good ol' multimeter works best. its what i use for checking a psu's voltage levels. i never use those power supply testers.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
