Macbook A2141 820-01700 No Image screen and extern
    Hello friends
    here reporting after time.
    I have this board 820-01700, it turns on and consumes almost 4 amps but it does not display an image on the screen and also an external monitor
    shift key is activated and the touch bar lights up.
    test with a usb mouse the mouse light comes on.
    is it video?
    Re: Macbook A2141 820-01700 No Image screen and extern
    Does your touch bar display the graphics or only lights up ?
    This model is impacted by FLEXGATE (for the LCD panel) but that does not affect your external display not working.
    If the key caps LED is toggling, the OS is booted.
      The logo appears for 3 seconds, then a black screen appears, but the machine is still on.
        Check if the graphics are still present on the display with a flashlight / phone in torch mode - shine on the front of the display to view it.
        If yes but is dark, then the fault is with the backlight circuit.
          Hi
          updated
          It had two failures, screen and board.
          the customer picked up. a lot of expense he said.
          Thanks friends
            Hi there. You mentioned that this model had flexgate issue too. I'm planning to buy one wich is perfectly working on external display and only backlight is not working (you can clearly see image on internal display panel using a torch). That could be both backlight circuit or backlight display flex at this point?. I have not a working display to test in case I decide to proceed and buy.
