Fish Tank LED Power Supply Gets Hot then shuts down
    A good friend of mine brought to me a rather large LED light array that is used for fish tanks. IT's so large in fact, that it requires TWO ATX style power supplies.
    He told me that as soon as he turns it on, the LEDs turn on, but then shortly turn off.
    I tried powering the lights with just one power supply, but they wont power with just one, so with both turned on, the lights do turn on, but then they turn off.
    The power supplies are identical, and one of them seems just fine, but the other one ... within 10 seconds after connecting it to power, the two heat sinks get too hot to touch... so it seems like it might be shutting itself down before it burns itself out.
    Here are some pictures
    I understand a little about ATX power supplies ... that there's a high side and a low side and usually a PWM chip that drive a transformer and also usually a comparator chip that keeps an eye on voltage levels etc.
    Since one heat sink is on the high side and the other on the low side, its puzzling to me that both of them are getting that hot that quickly. And of course I'm not sure which fet on either heat sink is the one drawing all that current...
    Advice on how to move forward here to figure this out?
    Thank you,
    Re: Fish Tank LED Power Supply Gets Hot then shuts down
    More information about the LED is required. It's surprising to have one lamp powered by 12V or whatever directly, unless it was meant for off-grid use perhaps.
    Input/hot side has transistors on them and usually there are 2 plus one for standby.
    Output/safe side has all diodes on it pretty much.
    Some PSUs have protection to ensure you're not drawing too much but either way, as you increase load, it will dissipate more heat - both input and output side.
    I don't like high/low side because it could mean the high/low side transistor on the hot side to implement complementary drive.
      12v leds or 24v leds with psu's in series?
      or 5v leds?
      whats the wiring??
        Can we see the data plate for these switching power supply
        What I would do is work on the switching power supply that is having the issues of heating up very quickly but I would use some automotive head lamps as a load I would check each switching power supply individually and not together assuming that they are 12 volts each do they have a 5 volt power supply rail if so what does it power
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          There is no data plate. Just this label which looks rather ... homemade to me ...
          Also, when I turn that power supply on WITHOUT a load connected to it ... the heat sinks of course do NOT get warm at all, but it does make this sound ... listen to all of it cause it gets more interesting about halfway through the audio.
          The noise is definitely coming from somewhere in the vicinity of the heat sinks.
          Also, the other power supply (the good one) does not make any noise when I power it up without a load. The chassis fan, however, does turn on.
          The "bad" power supply, the one making the noise, when I turn it on without a load, the chassis fan DOES NOT turn on, though I seem to remember it did turn on when it was under load though I can't be 100% certain on that.
          Here are some more pics of the unit itself and the output side of the power supply. I haven't taken the circuit board out yet to start probing around. I wanted to gain some more knowledge first and get the opinion of you more experienced guys before I start taking things apart just to make sure Im proceeding in the most effective way possible.
            or 5v leds?
            whats the wiring??
            See my most recent post.
              Looks like some dark looking LED’s… wonder if you got some bad ones? Test the individual string / individual LED’s with a bench PSU.
                Originally posted by CapLeaker View Post
                Looks like some dark looking LED's… wonder if you got some bad ones? Test the individual string / individual LED's with a bench PSU.
                Well I would if it weren't for this power supply that isn't working properly... 10 seconds after turning it on the heat sinks are too hot to touch. Yet the other power supplies heat sinks ae cool to the touch. Not to mention the noise the PS is making which I posted the audio here yesterday.
                  change all the small electrolytics.
                    What is the model number of the PSU? What IC's is it based on? I understand this light has 2 power supplies. One works good and the other one not? How are the PSU's hooked up to the 3 lights?
                    If I had to guess, I say the noise comes out of the big switching transformer between the two heat sinks. I would tear the PSU apart and check for cracked or dry solder joints.
                    Does this lamp (partially) run with only one PSU connected?
                      Did you listen to the sound file I posted?
                        no, not interested.
                        the heat issue is first - it sounds like the driver transisters are being over-driven.
                        they are often driven through small blocking capacitors
                          no, not interested.
                          Ive got an ESR meter ... would that not help in isolating the problem?
                          Also what would be causing the PS to shut off all on its own?
                            TWO ICs only
                            Through the two cords coming out of the housing each with a 4 pin round threaded connector ... reminds me of a CB Microphone connector from back in the day...
                            No it does not run at all with only one power supply.
                              Look at the PCB of the PSU if there is a brand and a model number printed on it. Could be along the edge or on a not so crowded area of the PCB.
                                no, not interested.
                                I took out the big caps which are printed as 680uF
                                The meter reads one at 740uF and the other as 750 uF
                                Meter is a Fluke 17B
                                  Only identifying markings on the PCB are these
                                    still trying to come to terms with how big this thing is or isn't. I recall my small 10 gallon fish tank only needing a small lamp, then when we're talking about a 40 gallon tank, a single F40T12 would be sufficient to illuminate it.
                                    Then there are LEDs now, those LEDs, 25 of them per set, so there's 75 of them total. If they were 1W a piece, 75 watts, that's a very bright lamp... but a single ATX-sized power supply should be more than sufficient.
                                    If they were 3W a piece, then 225W, which is REALLY bright, which a well designed single ATX-sized power supply is still sufficient, though 225W is a significant load but not unmanageable, a P4 with a GPU can get to 300W and we've had that for years.
                                    Then comes a 6A@120V power supply. I suppose that's inrush...but that's 720W...
                                    hmm...
                                      hmm...
                                      So I learned a little about the company that designed these ... apparently they were quite the item back in the mid 2000's but another company ... some aerospace company had gotten a patent on marine aquarium lighting that I guess was close enough to this exact lighting system that they sued the company and put them out of business. The company, PFO - had been making and selling these LED lighting units long before this other company was awarded a patent.
                                      Its a shame ... They apparently had a good reputation as a company of quality and customer service.
                                      Also, when these lights turn on briefly, they are different colors and they are not very bright
                                        So since the two big caps are reading at around 750uF when they are supposed to be 680uF ... are they bad?
