12v 1uo941243c Relay repairable?
    Re: 12v 1uo941243c Relay repairable?
    well - bohaboha will know what it does - because that function wont work now it's been removed
      yes that will be a big give away as to what its job is .
        Originally posted by petehall347 View Post
        think those relays are also used for dash lights
        I'm lost because I don't know which relay belongs to which function there is absolutely nothing in the car that shows. the manual only shows fuses. and I don't think this relay has to do with doors because I locked the car after I removed this relay
          try everything and see what wont switch on .
            i can see if i have a wiring diagram later .. where abouts in the car is the relay from ?
              it was under the dashboard
                what year is the car ?
                  it's possible that it's just what we see.
                  it reminds me of the circuit used with trailer sockets.
                  @bohaboha - do you have a tow ball and socket for a trailer on the car?
                    making me wonder why the relay was removed in the first place
                      it
                      is 2004
                        no nothing
                          was thinking itbelongs to the problem i have with this car
                            it would help us help you if you let us into the secret of what the problem is
                              does the relay plate hold 14 relays ?
                              please post a picture of the relay plate
                                OP doesn't give us the clear pictures, car year or wiring diagram or symptoms it's impossible to really help him
                                The diode trace has a run that goes nowhere... then I realized the trace is looking zapped.
                                One description is "relay for the instrument panel lighting controller, for vehicles without a central alarm". Another said with central alarm.
                                The 6-pins do not seem to have numbers so impossible to know what pin is overloaded and we don't have the car wiring info or a symptom.
                                  I'm just in the same situation because I don't know any more and I just have the fuse box information which is not so good. even for this relay after i train away it everything works so it's equally dark for me
                                    No it has only 7 relays
                                      The car starts but no spark so I thought it has to do with the fuel pump but I still don't know therefore I tried to find the fuelpumps relay.That's the problem and it's not solved but now I know which relay is for the fuelpump Hooray Hooray
                                        is it on the far right of the relay plate ?
                                          it is the third on the plate and it has a big number 309 about the midle of the plate in the leftside driver side (european car)
