Dell 5559 bios
    Re: Dell 5559 bios
    Thanks NAHI
    you save me on this 07/04/2019
    thanks for Badcaps team.net
    thnksss
      Re: Dell 5559 bios
      good morning everyone, I'm trying to reprogram the bios of a Dell Vostro AAL15 LA-D071P, I tried the bin tanveer920 file but it doesn't work, as soon as I connect the power supply connector the power-on led turns on for 10 seconds then the power off led and starts to turn the fan to maximum remains so, to turn off I have to disconnect the power, someone has solved this problem?
      many thanks, happy day
        Re: Dell 5559 bios
          Re: Dell 5559 bios
          Nahi bro thankyou very much.
            Re: Dell 5559 bios
            hola, tengo es mismo problema con un dell 5559 ya probe el dump que veo que les funciono a varios colegas pero el mio sigue en pantalla negra y el ventilador girando fuerte.
            Originally posted by Google Translate
            Hello, I have the same problem with a dell 5559 and I tried the dump that I see that worked for several colleagues but mine is still black and the fan is spinning hard.
              Re: Dell 5559 bios
              Originally posted by nahi View Post
              i don't know whats wrong, i exchange bios chip from a running laptop to another laptop same motherboard same laptop but not working, just fan spinning too fast,
              dell 15 la-d071p
              i have the same problem
                Re: Dell 5559 bios
                Clean the ME firmware .
                  Re: Dell 5559 bios
                  thanks its working.
                    Re: Dell 5559 bios
                      Re: Dell 5559 bios
                      thank you
                        Re: Dell 5559 bios
                        Thank you so much
                        i check vinafix 10 bios no disply
                        your bios work 100%
                          Re: Dell 5559 bios
                          i solved my problem with this file.......
                          Thanks Full operation
                            Re: Dell 5559 bios
                            Thank you very much you are a life saver
                              Re: Dell 5559 bios
                              tks bro
                                Re: Dell 5559 bios
                                this file using blank screen fan running fast help me please!
                                  Re: Dell 5559 bios
                                  post the original bios
                                    Re: Dell 5559 bios
                                    tested working fine. Thank you!
                                      Please Someone Can Clean ME for this LA-D071P Bios?
                                      BOARD: AAL15 LA-D071P REV 1.0 2015-07-06
                                      LAPTOP MODEL: Inspiron 5559
                                      NO GFX INTEL ONLY
                                      PROBLEM: Sometimes it will power on and other day not using it wont power it will just turn of maybe I ll try the bios Thanks in advance
                                      OLD BIOS attacehd:
                                      Last edited by SMDFlea; 02-27-2021, 08:39 AM. Reason: Added LA-D071P to generic thread title
                                        Re: Please Someone Can Clean ME for this Bios?
                                        use this
                                          Originally posted by shabi View Post
                                          use this
                                          fan turns so fast no dispplay
