Clevo 6-71-W65S0-D02 need Bios
    Clevo 6-71-W65S0-D02 need bios dump
    Re: Clevo 6-71-W65S0-D02 need Bios
    https://repo.palkeo.com/clevo-mirror/W6xxSB/
      Not working
        hi please help bios need
          Log into the palkeo site linked above using
          Username: repo
          Password: repo
          Download bios version B0304.zip ,extract the folder.The update has a 4MB bios and 6MB,so the 6MB needs splitting to 2 and 4. Open W650SB.6M with a hex editor https://mh-nexus.de/en/downloads.php?product=HxD20 ,select-block 0 - 1FFFFF (200000 in length is 2MB in hex),cut and copy into a new file and save as 2MB.bin ,then save the remaining 4MB bios.Flash both the 2 and 4MB bios .
          To update the EC (E0304) copy the files from the extracted zip folder onto a bootable USB flash drive https://rufus.ie/en/ ,boot from it and run ECFLASH.bat
          Last edited by SMDFlea; 06-10-2022, 05:16 AM. Reason: 200000 (two hundred thousand,not tweny thousand)
            Username: repo
            Password: repo
            Download bios version B0304.zip ,extract the folder.The update has a 4MB bios and 6MB,so the 6MB needs splitting to 2 and 4. Open W650SB.6M with a hex editor https://mh-nexus.de/en/downloads.php?product=HxD20 ,select-block 0 - 1FFFFF (20000 in length is 2MB in hex),cut and copy into a new file and save as 2MB.bin ,then save the remaining 4MB bios.Flash both the 2 and 4MB bios .
            thanks a lot i will try
              Username: repo
              Password: repo
              Monster ABRA A7 V5.1.2
              Thank you working
