HP 9470m Change MAC ADRESS
    Hi!
    I've programmed 5 pieces of this model from this forum dump and I have an address conflict on the network. The problem is that laptops (dump) have the same MAC address. I tried to replace it by editing the dump, but after such a procedure the LAN card is completely not detectable. Please help me with which tool can I change the MAC address?
    Thank you for every clue
    Re: HP 9470m Change MAC ADRESS
    You need NbDmiFit .Start with the newest ,then if that doesn`t work go backwards, 2.11,2.10 etc . Look here:
    https://www.badcaps.net/forum/showth...light=nbdmifit
      Thanks for your replay. I try NbDmiFit but it allows to change serial numbers- not MAC adress
        Try version 2.02
          i had the same problem with 200 9470m, i sended them back to the seller.
          try bios programming and dmi.
          you have to remove the eeprom, program it with a new "blank" bios with uuid fffffffffffffff, solder back and use dmi to fix.
          because you have 5 it may be cost effective to do it, but in my case with 200 laptops and wasn't worth it...!!! good luck.
            anyone who try other methode?
            When the laptop wants to add to new domain (from Azure ), it says the laptop is connected to another domain. Apparently the mac adress is the problem
              I have probook 430 g4 and it allow me to change mac from bios menu. haven't you try from bios?
                thanks, but with 9470m is not possible.
                  https://www.groovypost.com/howto/cha...indows-10-why/
                    Then you should flash bios again.
                      Thanks, but why i read in #5, with a new "blank" bios with uuid fffffffffffffff
                      Is een bin from badcaps not working.
                      For HP i am using Unlocker
                        Clean the ME firmware
                          Why can you not change the MAC ADDRESS with the utility linked earlier ?
                          We have done this with success for mac address locked CAD tools so that we can develop at the office or home office.
                            thanks for your answers..
                            i remove bios password for +20pieces of 9740m with Unlocker. Without any problem.
                            The buyer of this laptops could not add to new domain cause mac adress..
                            Next time i clean ME firmware and i see what happend.
