Lenovo Thinkpad L460 Type 20FV NM-A651 BIOS (Main + EC) Needed
    Laptop is a Lenovo Thinkpad L460 Type 20FV.
    Mainboard is BL460 NM-A651 Rev 1.0
    The laptop takes a long time to POST, then shows the Lenovo screen and shuts down promptly. Cannot select startup device menu or BIOS.
    Think it might be a corrupted BIOS maybe. Anyone had this problem before?
    Re: Lenovo Thinkpad L460 Type 20FV NM-A651 BIOS (Main + EC) Needed
    Try this
      Thanks simpleway tested wok for me
        I tried with the file, but the laptop does want to start.Some suggestions?
          post the bios backup here
            Thanks for flashing the BIOS. It’s a pity that it didn’t help if you have the opportunity to tell on the bl460 board where to find the dump and the program on it
              Originally posted by simpleway View Post
              Try this
              HI, it's the same content in UC8M2 and UC8M1? can I use the dump for both spi bios.??
                Post both your bios backups. The L460 Type 20FV bios is split across 2 X 8MB bios chips, it has vPro support.The other 8MB bios versions are non vPro.
                  hi bro
                  I Don't have the originals dumps because this laptop came to me from another technician who has already flashed the two bios
                  in my case I have n vpro model 2x 8 Mega spi
                    Both bios at post #2 are both non vPro, checked both with MEAnalyzer and they`re both "initialised" which means the ME needs cleaning. If you don`t know how to do that one of the members will sort it. The bios should be flashed to UC8M1 only
                    EDIT: i see you`ve edited your post now. What do you have vPro 2 X 8MB or non (not) vPro 1 X 8MB
                      EDIT: i see you`ve edited your post now. What do you have vPro 2 X 8MB or non vPro 1 X 8MB
                      referring to the schematics the vpro model is with 2x16 Mega and non vpro like mine is 2x8 mega see attachhed picture,
                      I did clean ME and flash UC8M1 with, board power on for 40 sec and restart in loop (every 40 sec ) I attached my clean ME dump
                        I did not understand sorry
                        I confirm as you mentioned that for the non vpro is 1X 8 mega spi and for the vpro 2 X 8 mega spi
                        for my case I have two 8 mega spi which means vpro model I am dead bro
                        see page 8 in schematics
                          i
                          Hii i need to lenovo l460 power on no display problem and bios password problem
                            Help!
                            L460 NM-A651 black screen
                              Lenovo L460 Laptop (ThinkPad) - Type 20FV
                              Hello to all.
                              I need a BIOS Dump for this L460 . Used to work few minutes ago 100% , the reason that stopped working (with 5 short single beeps) is that i tried to unlocked the DXE driver (supervisor). (already done it to another one, and succeed just fine).
                              Don't know why it got stuck ,and now it doesn't accept the original dump as well, i believe that it wasn't verified , correctly or read correctly.
                              Anyone have the original BIOS Dump ?
                              I am posting the original bios dump (which it was working, but suddenly after the dxe stopped).
                                Re: Lenovo L460 Laptop (ThinkPad) - Type 20FV
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  You are a legend.
                                  It's back and running.
                                    Thanks dear its me cleaned and worked flawless
                                      HI...i need bios bin for non vpro..mine has 1 8 mb chip....no display...the power button blink 2 times and shuts down.after powering on...
                                        Hi can someone help me fix my bios files for nm-a651 type 20fv. It runs but no display here is original dump files
