MacBook Air 820-00165 Random Crashing
    Hello. I have a random crashing problem on a 2017 820-00165. It has crashed during startup and the other day it froze for about 8 seconds after running for more than an hour, then powered off. I ran Memtest through the 4 passes and no errors were reported. The board is clean with no corrosion or previous work anywhere. I'm hoping someone has seen this before. if this is not enough I can provide more.
    Below is part of the crash report.
    Code:
    System Integrity Protection: enabled
    Crashed Thread:    3 Dispatch queue: CLInternalServiceSilo
    Exception Type:    EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes:    KERN_INVALID_ADDRESS at 0x000044f9f4976918
    Exception Codes:    0x0000000000000001, 0x000044f9f4976918
    Exception Note:    EXC_CORPSE_NOTIFY
    Termination Reason:  Namespace SIGNAL, Code 11 Segmentation fault: 11
    Terminating Process:  exc handler [183]
    VM Region Info: 0x44f9f4976918 is not in any region. Bytes after previous region: 75835781417241 Bytes before following region: 29712775157480
       REGION TYPE          START - END     [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
       CoreServices        10fb6c000-10fc76000  [ 1064K] rw-/rwx SM=COW
    ---> GAP OF 0x5ffef038a000 BYTES
       MALLOC_NANO       600000000000-600008000000 [128.0M] rw-/rwx SM=SHM
    Application Specific Information:
    objc_msgSend() selector name: __setObject:forKey:
    Thread 0:: Dispatch queue: com.apple.main-thread
    0  libsystem_kernel.dylib    	  0x7ff804e2fc4a mach_msg_trap + 10
    1  libsystem_kernel.dylib    	  0x7ff804e2ffbb mach_msg + 59
    2  CoreFoundation        	  0x7ff804f2f544 __CFRunLoopServiceMachPort + 319
    3  CoreFoundation        	  0x7ff804f2dc0b __CFRunLoopRun + 1329
    4  CoreFoundation        	  0x7ff804f2d005 CFRunLoopRunSpecific + 567
    5  CoreFoundation        	  0x7ff804fb41c2 CFRunLoopRun + 40
    6  locationd           	    0x109a003a2 0x109681000 + 3666850
    7  locationd           	    0x109a00d2c 0x109681000 + 3669292
    8  locationd           	    0x109a032fb 0x109681000 + 3678971
    9  dyld             	    0x109e814d5 start + 421
    Re: MacBook Air 820-00165 Random Crashing
    Sorry, I meant to say that I have swapped out the SSD and WiFi / BT card. This problem occurs on battery and on charger.
      I also did an Apple diagnostics on this computer and it was a complete pass. Very strange as there is no corrosion for previous work on this board.
        Try the SAFE MODE boot:
        https://discussions.apple.com/thread/3734077
        and post your results.
          Thanks mon2.
          I put it into safe boot mode and it crashed after running for less than an hour without touching the computer. Next I tried to restart it and it froze for about 15 seconds after displaying the background but nothing else. No crash reports were made available after those crashes but I do have one from July 31st that I can share.
          Code:
          Crash report July 31 2021
          Translated Report (Full Report Below)
          Process:        skywalkctl [881]
          Path:         /usr/sbin/skywalkctl
          Identifier:      skywalkctl
          Version:        ???
          Code Type:       X86-64 (Native)
          Parent Process:    Exited process [719]
          Responsible:      sysdiagnose [593]
          User ID:        0
          Date/Time:       2021-07-31 17:52:45.2143 -0400
          OS Version:      macOS 12.0 (21A5284e)
          Report Version:    12
          Anonymous UUID:    036F6C6D-6A3B-F4A9-A45D-CACD9ADDA8A3
          Sleep/Wake UUID:    A11E5169-BB1F-4F72-894E-66357606CAFD
          Time Awake Since Boot: 760 seconds
          Time Since Wake:    120 seconds
          Crashed Thread:    0 Dispatch queue: com.apple.main-thread
          Exception Codes:    KERN_INVALID_ADDRESS at 0x0000000000000000
          Exception Codes:    0x0000000000000001, 0x0000000000000000
          Terminating Process:  exc handler [881]
          VM Region Info: 0 is not in any region. Bytes before following region: 4534226944
             UNUSED SPACE AT START
             __TEXT           10e42d000-10e449000  [ 112K] r-x/r-x SM=COW ...in/skywalkctl
          Kernel Triage:
          VM - Fault hit memory shortage
          Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
          0  libsystem_c.dylib       	  0x7ff80358254c uuid_unpack + 4
          1  libsystem_c.dylib       	  0x7ff8035824cb uuid_compare + 28
          2  skywalkctl          	    0x10e4307df 0x10e42d000 + 14303
          3  skywalkctl          	    0x10e4307fc 0x10e42d000 + 14332
          4  skywalkctl          	    0x10e431522 0x10e42d000 + 17698
          5  skywalkctl          	    0x10e4392af 0x10e42d000 + 49839
          6  dyld             	    0x10ea854d5 start + 421
          Thread 0 crashed with X86 Thread State (64-bit):
           rax: 0x00007fb213400000 rbx: 0x00007fb3ba808200 rcx: 0x00007fb3ba809e80 rdx: 0x00d79435e50d7944
           rdi: 0x0000000000000000 rsi: 0x0000000112b2b828 rbp: 0x0000000112b2b810 rsp: 0x0000000112b2b810
            r8: 0x0000000000000000  r9: 0x0000000000000000 r10: 0x0000000112b2b8e0 r11: 0x0000000000000206
           r12: 0x00007fb3ba808200 r13: 0x00007ff844ebc8a0 r14: 0x0000000112b2b828 r15: 0x0000000000000000
           rip: 0x00007ff80358254c rfl: 0x0000000000010202 cr2: 0x0000000000000000
          Logical CPU:   1
          Error Code:   0x00000004 (no mapping for user data read)
          Trap Number:   14
          Thread 0 instruction stream:
           0f b7 45 de 66 39 45 ce-75 3d 0f b7 45 e0 66 39 ..E.f9E.u=..E.f9
           45 d0 75 33 8b 4d d2 8b-55 e2 0f c9 0f ca 39 d1 E.u3.M..U.....9.
           75 1c 0f b7 45 d6 0f b7-55 e6 66 c1 c0 08 66 c1 u...E...U.f...f.
           c2 08 0f b7 c8 0f b7 d2-31 c0 39 d1 74 13 31 c0 ........1.9.t.1.
           39 d1 0f 93 c0 eb 06 0f-93 c0 0f b6 c0 01 c0 ff 9...............
           c8 48 83 c4 28 5b 41 5e-41 5f 5d c3 55 48 89 e5 .H..([A^A_].UH..
           [8b]07 0f c8 89 06 0f b7-47 04 66 c1 c0 08 66 89 ........G.f...f.	<==
           46 04 0f b7 47 06 66 c1-c0 08 66 89 46 06 0f b7 F...G.f...f.F...
           47 08 66 c1 c0 08 66 89-46 08 8b 47 0a 89 46 0a G.f...f.F..G..F.
           0f b7 47 0e 66 89 46 0e-5d c3 55 48 89 e5 53 48 ..G.f.F.].UH..SH
           81 ec d8 00 00 00 48 89-d3 84 c0 74 29 0f 29 85 ......H....t).).
           50 ff ff ff 0f 29 8d 60-ff ff ff 0f 29 95 70 ff P....).`....).p.
          Binary Images:
            0x7ff803573000 -   0x7ff8035fbfff libsystem_c.dylib (*) <9382c3dd-2f3d-3a4f-89b6-8d88afb58a29> /usr/lib/system/libsystem_c.dylib
              0x10e42d000 -    0x10e448fff skywalkctl (*) <ebe0a0d3-44a0-3480-9942-f57b7175e2e4> /usr/sbin/skywalkctl
              0x10ea80000 -    0x10eae7fff dyld (*) <940ee8e3-5069-3969-9a75-224a23c908b1> /usr/lib/dyld
          External Modification Summary:
           Calls made by other processes targeting this process:
            task_for_pid: 0
            thread_create: 0
            thread_set_state: 0
           Calls made by this process:
            task_for_pid: 0
            thread_create: 0
            thread_set_state: 0
           Calls made by all processes on this machine:
            task_for_pid: 0
            thread_create: 0
            thread_set_state: 0
          VM Region Summary:
          ReadOnly portion of Libraries: Total=139.5M resident=0K(0%) swapped_out_or_unallocated=139.5M(100%)
          Writable regions: Total=6.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.6G(100%)
                          VIRTUAL  REGION
          REGION TYPE            SIZE  COUNT (non-coalesced)
          Kernel Alloc Once          8K    1
          MALLOC               6.6G    63
          MALLOC guard page          16K    4
          STACK GUARD            56.0M    1
          Stack               8192K    1
          VM_ALLOCATE             8K    2
          __DATA               211K    38
          __DATA_CONST            271K    34
          __DATA_DIRTY            58K    22
          __LINKEDIT            134.8M    5
          __OBJC_RO             80.8M    1
          __OBJC_RW             3024K    2
          __TEXT              4848K    43
          dyld private memory        1024K    1
          shared memory            24K    3
          TOTAL               6.9G   221
          Full Report
          {"app_name":"skywalkctl","timestamp":"2021-07-31 17:52:47.00 -0400","app_version":"","slice_uuid":"ebe0a0d3-44a0-3480-9942-f57b7175e2e4","build_version":"","platform":1,"share_with_app_devs":1,"is_first_party":1,"etl_key":"3","bug_type":"309","os_version":"macOS 12.0 (21A5284e)","incident_id":"BA2BCB21-2ABD-4C90-A1D7-0EB8FC464A82","name":"skywalkctl"}
           "uptime" : 760,
           "procLaunch" : "2021-07-31 17:52:40.5497 -0400",
           "procRole" : "Unspecified",
           "version" : 2,
           "userID" : 0,
           "deployVersion" : 209,
           "modelCode" : "MacBookAir7,2",
           "procStartAbsTime" : 756961823273,
           "coalitionID" : 741,
           "osVersion" : {
            "train" : "macOS 12.0",
            "build" : "21A5284e",
            "releaseType" : "User"
           "captureTime" : "2021-07-31 17:52:45.2143 -0400",
           "incident" : "BA2BCB21-2ABD-4C90-A1D7-0EB8FC464A82",
           "pid" : 881,
           "procExitAbsTime" : 761610887017,
           "cpuType" : "X86-64",
           "procName" : "skywalkctl",
           "procPath" : "\/usr\/sbin\/skywalkctl",
           "parentProc" : "Exited process",
           "parentPid" : 719,
           "coalitionName" : "com.apple.sysdiagnose",
           "crashReporterKey" : "036F6C6D-6A3B-F4A9-A45D-CACD9ADDA8A3",
           "responsiblePid" : 593,
           "responsibleProc" : "sysdiagnose",
           "wakeTime" : 120,
           "sleepWakeUUID" : "A11E5169-BB1F-4F72-894E-66357606CAFD",
           "sip" : "enabled",
           "vmRegionInfo" : "0 is not in any region. Bytes before following region: 4534226944\n   REGION TYPE          START - END     [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n   UNUSED SPACE AT START\n---> \n   __TEXT           10e42d000-10e449000  [ 112K] r-x\/r-x SM=COW ...in\/skywalkctl",
           "isCorpse" : 1,
           "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
           "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":881},
           "ktriageinfo" : "VM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\n",
           "vmregioninfo" : "0 is not in any region. Bytes before following region: 4534226944\n   REGION TYPE          START - END     [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n   UNUSED SPACE AT START\n---> \n   __TEXT           10e42d000-10e449000  [ 112K] r-x\/r-x SM=COW ...in\/skywalkctl",
           "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
           "faultingThread" : 0,
           "threads" : [{"triggered":true,"id":8471,"instructionState":{"instructionStream":{"bytes":[15,183,69,222,102,57,69,206,117,61,15,183,69,224,102,57,69,208,117,51,139,77,210,139,85,226,15,201,15,202,57,209,117,28,15,183,69,214,15,183,85,230,102,193,192,8,102,193,194,8,15,183,200,15,183,210,49,192,57,209,116,19,49,192,57,209,15,147,192,235,6,15,147,192,15,182,192,1,192,255,200,72,131,196,40,91,65,94,65,95,93,195,85,72,137,229,139,7,15,200,137,6,15,183,71,4,102,193,192,8,102,137,70,4,15,183,71,6,102,193,192,8,102,137,70,6,15,183,71,8,102,193,192,8,102,137,70,8,139,71,10,137,70,10,15,183,71,14,102,137,70,14,93,195,85,72,137,229,83,72,129,236,216,0,0,0,72,137,211,132,192,116,41,15,41,133,80,255,255,255,15,41,141,96,255,255,255,15,41,149,112,255],"offset":96}},"threadState":{"r13":{"value":140704284919968,"symbolLocation":0,"symbol":"__stderrp"},"rax":{"value":140402803867648},"rflags":{"value":66050},"cpu":{"value":1},"r14":{"value":4608669736},"rsi":{"value":4608669736},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":60680079189834052},"r10":{"value":4608669920},"r9":{"value":0},"r15":{"value":0},"rbx":{"value":140409904857600},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":518},"rip":{"value":140703184725324,"matchesCrashFrame":1},"rbp":{"value":4608669712},"rsp":{"value":4608669712},"r12":{"value":140409904857600},"rcx":{"value":140409904864896},"flavor":"x86_THREAD_STATE","rdi":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":62796,"symbol":"uuid_unpack","symbolLocation":4,"imageIndex":0},{"imageOffset":62667,"symbol":"uuid_compare","symbolLocation":28,"imageIndex":0},{"imageOffset":14303,"imageIndex":1},{"imageOffset":14332,"imageIndex":1},{"imageOffset":17698,"imageIndex":1},{"imageOffset":49839,"imageIndex":1},{"imageOffset":21717,"symbol":"start","symbolLocation":421,"imageIndex":2}]}],
           "usedImages" : [
            "source" : "P",
            "arch" : "x86_64",
            "base" : 140703184662528,
            "size" : 561152,
            "uuid" : "9382c3dd-2f3d-3a4f-89b6-8d88afb58a29",
            "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
            "name" : "libsystem_c.dylib"
            "source" : "P",
            "arch" : "x86_64",
            "base" : 4534226944,
            "size" : 114688,
            "uuid" : "ebe0a0d3-44a0-3480-9942-f57b7175e2e4",
            "path" : "\/usr\/sbin\/skywalkctl",
            "name" : "skywalkctl"
            "source" : "P",
            "arch" : "x86_64",
            "base" : 4540858368,
            "size" : 425984,
            "uuid" : "940ee8e3-5069-3969-9a75-224a23c908b1",
            "path" : "\/usr\/lib\/dyld",
            "name" : "dyld"
           "vmSummary" : "ReadOnly portion of Libraries: Total=139.5M resident=0K(0%) swapped_out_or_unallocated=139.5M(100%)\nWritable regions: Total=6.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.6G(100%)\n\n                VIRTUAL  REGION \nREGION TYPE            SIZE  COUNT (non-coalesced) \n===========           ======= ======= \nKernel Alloc Once          8K    1 \nMALLOC               6.6G    63 \nMALLOC guard page          16K    4 \nSTACK GUARD            56.0M    1 \nStack               8192K    1 \nVM_ALLOCATE             8K    2 \n__DATA               211K    38 \n__DATA_CONST            271K    34 \n__DATA_DIRTY            58K    22 \n__LINKEDIT            134.8M    5 \n__OBJC_RO             80.8M    1 \n__OBJC_RW             3024K    2 \n__TEXT              4848K    43 \ndyld private memory        1024K    1 \nshared memory            24K    3 \n===========           ======= ======= \nTOTAL               6.9G   221 \n",
           "legacyInfo" : {
           "threadTriggered" : {
            "queue" : "com.apple.main-thread"
           "trialInfo" : {
           "rollouts" : null,
           "experiments" : null
            Is your CPU cool or getting warm / hot ? Perhaps you can check with an IR thermometer.
            Maybe the CPU heatsink needs a fresh batch of thermal paste ?
              I don't believe the CPU is overheating. I run fan monitoring software and it tells me that the processor operates between 30c to 59c depending on what's going on. It runs close to 59c when I'm streaming videos as a stress test.
              This is a strange one because everything seems normal. When it locks up I still have a picture for as long as 10 seconds or so, then it reboots rather than powering down like the 820-3662 does with unstable VRM FETs.
              My next option may be to do a light reflow over the memory to see if that changes anything. I'm running out of ideas and it appears that few people have experienced it before.
                Yes, I agree. Have not seen this depth of a fault, yet.
                On the reflow, do so carefully and do apply flux to assist. I need to post closure for an A1466 repair on another thread. Have it working but was fun to fix a few issues.
                Specifically, @Piernov advice was great to review nearby areas that can corrode on the logic board. While doing my gentle rework, caused a short on the 3V42 rail. Had about 0.8 ohms to ground so lost the key power rail. After about 30 mins of testing my history on where the heat was applied, reviewed the SMC (TI device). Removed the corner stinky glue points with heat -> applied flux on each side of the BGA. Reflowed again till the BGA package started to "dance". You will hear a cracking sound when the balls are released off the board. Carefully nudged just a small bit by the edges a few times to remove any possible shorts. Did not remove the BGA off the board as this will then require reballing of the SMC. This worked 100% to fix the short I created in error.
                This also fixed the corroded logic board. The customer (university student) was so happy. Three repairs shops told her to throw it out as the repair would be > $1000. One actually said "you worked the logic board too hard and burned it out". What ??? Sad. She bought and returned her 2020 macbook to Apple out of fear that they cannot be repaired.
                  It's been a while but I've finally come back to this MacBook Air. It's still crashing randomly and I have done all the know methods to solve the problem. I decided to do some measurements on the board and found that the resistance to ground for the CPU is 8.9 ohms. I don't have another board to compare to, but the Haswell processor is supposed to have 18-23ohms. Not sure if this is a red herring or not. Would anyone have an actual measurement?
                    Resistance depends on the CPU speed. I've got a 2.2GHz CPU on my donor pile that measures 10 ohms or so. IIRC, this one had the same intermittent shutdown problem and was an Apple FRU as well. Very likely to be a disappearing power rail or PCH control signal.
                    I've had a couple of these Apple FRU boards with weird intermittent issues. Is this board you have a FRU by any chance? I know these CPU's warp when they are removed for reballing or replacement. One guy I saw used .45mm balls (as opposed to .4mm) to accommodate that. So who knows.
                      I appreciate you checking reformatt. it doesn't look like it's an FRU. There are no stamps or stickers indicating that. There is also no sign of liquid damage or corrosion at all. the board is very clean. The processor is a 1.6GHz i5. I just sold 2 2015 MBAs so I no longer have anything to compare to. I'm not buying any more Intel based Macs given the sliding prices.
                      I too thought this is a power rail dropping off which is why I started doing resistance measurements. The crash reports all reference a timeout on the CPU.
