My IBM thinkpad t60 switched to a screen mode where there are letterboxes around the Windows Display. How do I switch it back?
IBM Thinkpad T60 screen problem
Re: IBM Thinkpad T60 screen problem
Not sure what you mean - in Contral Panel>Display>appearance is it the difference between Windows Classical and Windows XP or whatever you have in there.Please upload pictures using attachment function when ask for help on the repair
Screen resolution? - showing desktop - righthand click> properties>settings - move slider
What were you doing when it changedPlease upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostScreen resolution? - showing desktop - righthand click> properties>settings - move slider
What I was doing - I had put it in standby and then when I powered it back on again, the problem occurred.
Perhaps when starting from standby it is not loading the driver?
Have you tried a full power off and start up. Check driver is latest.
Tried on external monitor?Please upload pictures using attachment function when ask for help on the repair
Sounds like the monitor's stretch feature decided to change (nothing to do with Windows). Usually this only affects video modes where the selected resolution is lower than the monitor's native resolution though.
I had a similar case with a very old Toshiba Satellite 440CX (non-CD drive version of the CDX). On my one there are no buttons on the monitor itself, just the backlight/contrast adjuster. It use to be fine for DOS games and the like (albeit pixelated since the monitor only does a nearest-neighbor stretch), after sitting for 2 years the only thing that fills the 800x600 monitor is 800x600 itself.
^ Those old Toshibas have an option in the BIOS to enable/disable screen stretching.
With the laptop off, hold down the ESC key and turn it on. Keep holding the key till an error message pops up telling you to hit F1. Press F1 and viola.. you're in the somewhat strange proprietary Toshiba BIOS.
And no.. there's no direct way (like on regular PCs) to get into the BIOS on these old grey (gray?) Toshibas, like pressing the DEL key or something. The ESC trick or an empty CMOS battery (rechargeable little battery pack on these) is the only way.
As for the thinkpad..
There should be an option in the BIOS (in config -> display or something along those lines) to enable/disable screen stretching, so that content which isn't in the native LCD panel resolution gets stretched to the full panel size or displayed in the original resolution (with black borders around it).
Make sure the laptop isn't set to "mirror mode", i.e. trying to display the same image on the internal LCD and the VGA port at the same time. This will limit your maximum resolution (usually to 1024x768 or something), and if stretching is disabled at the same time, you'll end up with a little 1024x768 image centered on the screen with black borders around it if your LCD's native resolution is higher than that (like 1400x1050 on some T60 models)
