i am looking for xp tablet edition to refurbish some tablet pcs i got (if anybody has a source for win xp tab edition it would help) and thought if xps EOL is next year what about the tablet edition? is it EOL too?
does the xp EOL affect the tablet edition to?
Follow the white rabbit.Tags: None
Re: does the xp EOL affect the tablet edition to?
What about test equipment which uses XP and previous versions?My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
Originally posted by japlytic View PostWhat about test equipment which uses XP and previous versions?
You can use it, but no security updates. Most test equip isn't internet connected, so unless it has USB too, it's not an issue.
What i do wonder is how XP activation will work...sigpic
(Insert witty quote here)
Originally posted by ratdude747 View PostWhat i do wonder is how XP activation will work...
am i still able to reinstall xp on machines in the process of being refurbished after the EOL?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
I would assume that you won't be able to activate it after April next year (I may be wrong on this but I believe XP is the first OS with WPA to reach the end of extended support?)
As for Embedded systems and other stuff that uses XP, I don't see an issue there unless you need to reactivate for some reason (most ATMs I've seen "crashed" are still running NT4 or win2k, I maintain CCTV systems that run on Win2k and there are access control systems out there that still use 98!)
its not me that has to keep activating machines into next year, its the non-profit i work with denvertechforall that does. i work with the "odd ball" machines, the tablets, all in ones, linux machines, server, etc so its not f too much concern for me. anyway the xp os these tablets run is basicly xp pro with added software.
thanks for the info people.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Originally posted by Elysarian View PostI would assume that you won't be able to activate it after April next year (I may be wrong on this but I believe XP is the first OS with WPA to reach the end of extended support?)
As for Embedded systems and other stuff that uses XP, I don't see an issue there unless you need to reactivate for some reason (most ATMs I've seen "crashed" are still running NT4 or win2k, I maintain CCTV systems that run on Win2k and there are access control systems out there that still use 98!)sigpic
both? i mean its hard to run 7 on hardware meant for 2k with an xp sticker!Last edited by goontron; 07-04-2013, 12:44 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
I think Windows 7 is usable on lots of old computers. It runs fine on old S478 P4's as long as they have over 1GB of RAM. It seems to be more efficient with older hardware than XP does and doesn't get as many memory leaks when running programs
Originally posted by Pentium4 View PostI think Windows 7 is usable on lots of old computers. It runs fine on old S478 P4's as long as they have over 1GB of RAM. It seems to be more efficient with older hardware than XP does and doesn't get as many memory leaks when running programs
Also ran Win7 on an Asus P4B motherboard. Ran pretty well there as well.
Then... I tried Win7 (and WinVista) on an Abit SR7-8X motherboard. Couldn't install the AGP Bus drivers, therefore making the board virtually useless for both OSes. Didn't have a newer PCI graphics card back then, either. You also had to use a Windows Vista Boot CD to even setup Windows 7 on it.Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
I have two v2s and one v1.
I am still looking at these boards nearly every day.
What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
Originally posted by Ami Sapphire View PostThen... I tried Win7 (and WinVista) on an Abit SR7-8X motherboard. Couldn't install the AGP Bus drivers, therefore making the board virtually useless for both OSes. Didn't have a newer PCI graphics card back then, either. You also had to use a Windows Vista Boot CD to even setup Windows 7 on it.sigpic
Originally posted by Ami Sapphire View PostYep, but it depends on the board. I tried Win7 on an old BIOSTAR U8798 Pro P4 board with 2GB of DDR400 RAM. Ran surprisingly efficient, but unsurprisingly, it didn't like the onboard sound (never worked).Last edited by RJARRRPCGP; 07-04-2013, 04:59 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
