Ratdude's Main Rig V6
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Coming soon: I'm building (er, upgrading) another workstation... in due time.
    Why? V5's board fried it's LAN chip (or the BGA joints failed), and another x7dwa-n to replace it is, ahem, not in the cards. For now I can use a USB 3.0 adapter, but with the system not always stable (especially when the LAN tries to start working on occassion), I'd rather not keep it that way long term.
    However, I did best offer this beuaty down to $85 shipped:
    http://www.ebay.com/itm/Supermicro-X.../372077037122?
    Which will be my starting point.
    I will be resuing about 60-75% of the parts from V5.5:
    https://www.badcaps.net/forum/showthread.php?t=53867
    Nice thing is since the current case uses modular PSUs, I have room for such an enhanced-EATX board. The versions that use regular ATX-size PSUs only go up to "regular" EATX.
    What will have to change (needs purchased/obtained):
    • I/O shield (none pictured, readily available on ebay)
    • CPUs (need to decide which model to go for)
    • Coolers; I need to decide what style as my case has the ducting and fans to run passive ones like intalled but I don't know what TDP they're rated for
    • SAS card (as my beloved UIO card isn't compatible, but at the end of the V5 thread I came up with ideas)
    ...and RAM, which is why this will be an "in due time" project. ECC DDR3 (the good fast kind) is still a but pricey it seems, so it may be a while until I can get some. I've seen it for $50 for 16GB, which would work, but $85 is as much as I dare spend at the moment.
    This will be fun...
    sigpic
    (Insert witty quote here)
    master hoarder
    • May 2008
    • 12168
    • Bulgaria
    Re: Ratdude's Ming Rig V6
    What's a "Ming Rig"???
    Sorry, I couldn't resist this trollolol moment.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Mods: Please fix my bleeping thread title.
      sigpic
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        Re: Ratdude's Main Rig V6, since I murdered my X7DWA
        Fixed it fer ya.
        The market is flooded with 56xx-series Xeon processors right now. SLBVY 3.6GHz is the fastest quad core Westmere, a pair can be had for 80~90 all day long. SLBVX is the fastest hex-core Westmere @ 3.46, they're still up there a little @ around 200 or so for a pair. I don't see you doing anything that would tax 12 cores though, I'd take the extra speed and 8 cores.....but that's your call.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by Topcat
          Fixed it fer ya.
          That isn't what I had in mind...
          Noted. I've seen some as cheap as $30 a pair. I'll have to see...
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16955
            If you want to get it up & running, I have a pair of Nehalems @ 2.26 (e5520) for free.
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Also noted... until I have RAM sourced the CPU issue is irrelevant. This board has a CPU and cooler, so for testing I'm covered. Obviously I'll want to do better than that for the real build.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16955
                4gb (smallest available) modules are a dime a dozen... 16gb (largest supported) modules are still pricey and harder to come by.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Which is what I figured. This beast has 18 slots for DDR3, but I bet filling them with 4gb modules won't work due to the limitations on ranks. I'll have to hit up the manual and see... 32GB is what V5 has but If I had to run 16, fine. Downgrade but whatever.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Well shit. If I want to run at the full 1333, I'll have to limit myself to 6 RDIMMs, one per channel (single or dual rank only). Like with the Opterons, one can choose speed or slots, or a mix, but not all of both. 24GB would be the max using 4gb modules, which are indeed substantially cheaper than the big stuff.
                    Edit- What the hell, threw in an offer for 6 of such... They do make 1gb and 2GB modules, but the pricing on those isn't much different (and I'm not that much of a cheapass). 24GB, while a downgrade, from what I can tell will be a good starting point at least.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Look what I found:
                      http://www.ebay.com/itm/LSI-MegaRAID...torefresh=true
                      Any good?
                      edit- Bought it.
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        As per Topcat's suggestion, I went ahead and ordered a spare BBU:
                        http://www.ebay.com/itm/LSI-BBU06-Ba...ontroller-raid
                        Not too pricey.
                        Still figuring out CPUs and coolers... but dang, since I found a cheaper fix for RAM (and BTW if I go with Westmere's, I can do up to 6 modules per CPU at 1333, not 3 ), maybe this will build up faster than I expected.
                        Something else Topcat pointed out is this thing can do SLI... and since they provide 3 slots between the two 16x slots, if I found another GTX 970 like I'm running now (espcially an identical chinese Zotac with the same OC speed), then I could make it work and still have RAID and USB 3.0. I'll probably axe the TV tuner (what I have now is PCI, and while I have a PCIe one sitting, I never use the thing), so this would be a viable future upgrade. We shall see...
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Bought CPUs:
                          http://www.ebay.com/itm/PAIR-Intel-X...gAAOSw3YJZRDbu
                          They're the fastest E-series 6 core units. The fastest quad core E series is not much faster clockspeed wise (2.67 vs 2.53), but with the future being multi threaded (hell my freaking HTC M9 has 8 cores!), I think it's worth a little extra to have more cores.
                          I went with E series because they're only 80W a pop (not 95-130 in the X series), and I like things cool and quiet. Also, they're substantially cheaper; if I need more speed I can spend big bucks later.
                          Still working on RAM... nobody accepts reasonable offers it seems. At least I tried what topcat tried and was shot down (unlike topcat, lucky bastard).
                          RAID card came in today. Haven't tested it yet, but I like what I see. Even has an activity LED header so if I wanted to add in one of my breakout boards (to map the HDD LED to the card), I could. I probably won't, as I have activity lights on all 8 HDDs already.
                          At this point, it's RAM and coolers... and then I can convert V5.2 to V6.0.
                          Edit- the coolers I want: http://www.ebay.com/itm/Dynatron-G65...QAAOSwSlBYvMBr
                          But steep pricing (OK, not really, more like I don't want to spend that much right now). I want to use my fan duct, so I need a 2U cooler (so a Cooler Master Hyper TX3 evo or the like won't do). I'll see if there are other options as I don't know what the supermicro fanless ones are rated for in a duct (since I'm not running an L series CPU or the like).
                          sigpic
                            master hoarder
                            • May 2008
                            • 12168
                            • Bulgaria
                            No, you are right - $30 is quite a bit on the high side for a heatsink, especially a small one with a small fan. Probably wouldn't matter in a server room full of loud servers, but why would you want to use that as a main "rig"?
                            Need the small/slim form factor? Why not go with liquid cooling, then? You might even be the first one to ever put liquid cooling on server hardware, lol.
                            On the more serious side of things, what are the heatsink's physical size requirements? Sometimes, you can find one from a similar workstation/server on eBay for much cheaper. I've seen full-sized all-copper heatsinks sell just for the price of shipping ($7-10) - a steal if you ask me!
                            Fixed it fer ya.
                            Lol, nice one.
                            RD, how many boards have you murdered for your main rigs so far?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              2U. 2U dynatrons barely fit (which is good) in the fan duct. Not too loud when PWM controlled.
                              Lol, nice one.
                              Here's all of the boards that I can remember failing in a main rig:
                              Pre main-rig V2:
                              -Tyan dual slot 1 board (DOA due to bad caps, the board that brought me to BCN)
                              -AMI Dual Slot 1 coppermine (died years after being retired, asterisk)
                              -Some asus 939 gamer board (never did work right, does that count?)
                              -Supermicro PDSGE: the first board Topcat ever gifted me, had a bad 775 socket, served my parents well after I was done with it (still in the "main rig" I used it in), died one day never to run again. I converted it to fanned northbridge heatsink, and I suspect the fan failed, cooking the northbridge (used in a hot attic). Case and PSU eventually reused for X5DAL rig #2.
                              -Gigabyte dual 462 board: topcat freebie #2, failed recap killed one CPU socket, which ultimately led to main rig V1 being gutted and swapped for the third board he gave me, main rig V2
                              Post Main rig V2:
                              -Supermicro X5dal-tg2: Main rig V2.x. Dead for a while due to bad BIOS mods, revived with a fresh chip direct from supermicro. Ran for a long time after that. Currently not running but PSU recap failure suspected (need to order caps, doh!)
                              -Supermicro X6DAE-G: Main rig V4.1 One USB header port fried from day one. Another bad bios mod killed it. Replaced with a cheaply scored X6DA8-G2, although I could use said replacement board to hotflash the bricked chip to revive the X6DAE-G if I ever wanted to.
                              Tyan S2885 Thunder K8W (X2): Main rig V3.0 Never ran right due to AMD AGP bridge horse puckey (no drivers for anything other than win98, win2000, and winXP x32). One has a wrong cap replaced and bloated (never got to fixing), the other had a recapped joint fail in storage (cap fell off???). Both are probably fixable if I ever had a use for them
                              Tyan S2895 Thunder K8WE: main rig V3.5. Died one day when a CPU socket fried. Oddly will run off the other socket if only one CPU installed. Fried when Main rig v5.0 was a confirmed to exist in the future; the V3.x line did come back later when V5.x rejected most of the V3.x parts and I obtained a much better Supermicro H8DCI to replace it (still runs as my wifey's rig, V3.8)
                              X7DWA-N (V5.x): Not fully dead, but the NIC fried at the same time I installed a new GPU, never to work fully again. When it does "work" the sytem BSODs a lot. Due to the intermittent nature I presently suspect a BGA failure but without a hot air station I can't say for sure. Might be investigated down the road as a future project.
                              Board came in today. I have pictures, which I'll put in a fresh post.
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Bought more things... RAM (in mail), I/O shield, and a failed attempt at coolers.
                                Turns out adding fans to the fanless cooler included (and a second clone) doesn't work as the RAM slots and the like are too close for a fan sticking out. I tried cutting the fins down to add clearance, but all that did for me is ruin a fanless cooler.
                                So dynatron's it is. Found some with a best offer, wish me luck.
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  I owe you all pics.
                                  She's running... sorta. Only detects half of the 24GB of RAM I installed... and on top of that, it only says I'm in single channel. Huh?
                                  I followed the memory order in the X8DAH manual (DIMM1 first)... which would mean DIMM1A/B/C on each CPU, right? Running 6x 4GB DDR3 ECC's
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Funny, now it shows all 24GB but still single channel?
                                    Maybe I need to do DIMM1A, DIMM2A, and DIMM3A instead?
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Looked at a table in the manual... Yup, I did it wrong. 123, then ABC. Doh!
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Fixed. Will run novabench on it... and pics will come tomorrow.
                                        sigpic
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Hi everyone,
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
