Asus Z370-F Strix Gaming - Bent pins - Not powering up
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Hi guys,
    I've got this nice mobo with some CPU bent pins.
    Made it to put them back to their position, but one of them was too twisted and broke down.
    Anyways none of them are shorting together now.
    I had a i3-8100, a DDR4 2400mhz 8GB stick and a power supply, so gave it a try. Power led of the mobo is orange, but when shorting PWR pins, no joy
    Made some quick random measurements, 3.3V is present in the PWR button pins, I can see 5V also present.
    Measured around SIO chip and 3v are present in some caps.
    Im not sure if board should start even without CPU and ram connected, but I gave it a try and also no joy.
    For those who could have more experience with these mobos, do you consider this a waste of time and just keep it for parts?
    The ROG leds also turn on when power is connected as you can see on the pics.
    Also Ive marked the bent pins zone, and in smaller red circle the broken pin.
    Power led is orange, and the 4 leds in green rectangle (boot,cpu,ram,gpu) dont turn on at all in any moment.
    Garbage?
    Or should I try something else?
    Thanks guys!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Asus Z370-F Strix Gaming - Bent pins - Not powering up
    I can't tell what it is. Either VCCPLL or the one under it that I can't read
    https://en.wikichip.org/w/images/a/a...in_diagram.png
    anyways, no, it won't boot without the cpu/gpu (same thing in this case) or memory
      • 30977
      needs a new socket,
      in my experience the pins dont actually bend - they just come off the pcb pad.
      • magneh
        • Apr 2014
        • 588
        • Portugal
        Thanks for the inputs.
        What I wanted to know is if the board should fire up without CPU on it.
        As it does not turn on with or without CPU on this case...
        If it does not turn on at all without it, I will still invest time on it.
        Thanks!
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          I see this question asked way too many times: can a motherboard be tested without a CPU?
          - NO
          Testing a motherboard without CPU and RAM is absolutely pointless - it will tell you nothing about the working condition (or lack thereof) of the motherboard. Always install CPU (with heatsink/cooler!) and RAM as a minimum. Graphics card too if no integrated video.
          And speaking of heatsinks - your chipset needs one! Running the board without it will surely burn it out.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            - NO
            actually some specific newer motherboards can get to the cmos settings without a cpu, but it can't do a proper post without one
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              I would say testing without RAM is useful too: the board should produce a beep code to say there is no RAM installed.
              While having bad/wrong type of RAM can make the board unable to produce that beep code.
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                You're right.
                I do actually use that trick once in a while when a board powers up but doesn't want to POST. The thing is, not all boards will produce a beep code with no RAM (certain HP OEM boards, for example... IIRC.)
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  The RAM not being seated properly is often the cause of a mute motherboard. (when symptom resembles a dead CPU) (no bleeping at all)
                  Common with my Asus socket 775 motherboards.....
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    do pci-e diagnostic cards still work with these new heavily customized bioses?
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Originally posted by stj
                      needs a new socket,
                      Not always. I did revive a Supermicro PDSGE board (Pentium 4 775) with bent pins with some careful sewing needle work. The CPU falsely reported as a P4 Extreme edition (on the bios splash screen), but otherwise, it ran great for years until an unrelated chipset heatsink mod failed and burnt said chip
                      I say try it, what's there to loose?
                      sigpic
                      (Insert witty quote here)
                        ASUS ROG G531GT-BQ091T-GAMING Notebook Strix Specification for Upgrade or Repair
                        This specification for the ASUS ROG G531GT-BQ091T-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G531GT-BQ091T-GAMING boardview and G531GT-BQ091T-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 03:21 PM
                        ASUS ROG Scar II GL504GV-ES020-GAMING Notebook Strix Specification for Upgrade or Repair
                        This specification for the ASUS ROG Scar II GL504GV-ES020-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar II GL504GV-ES020-GAMING boardview and Scar II GL504GV-ES020-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 07:50 AM
                        ASUS ROG Scar II GL704GV-EV024-GAMING Notebook Strix Specification for Upgrade or Repair
                        This specification for the ASUS ROG Scar II GL704GV-EV024-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar II GL704GV-EV024-GAMING boardview and Scar II GL704GV-EV024-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        ASUS ROG GL703GM-71250-GAMING Notebook Strix Specification for Upgrade or Repair
                        This specification for the ASUS ROG GL703GM-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-71250-GAMING boardview and GL703GM-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 07:02 AM
                        ASUS ROG GL703GS-71250-GAMING Notebook Strix Specification for Upgrade or Repair
                        This specification for the ASUS ROG GL703GS-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GS-71250-GAMING boardview and GL703GS-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
