Is this cap good or bad
  • powrslave
    • Jun 2020
    • 6
    • usa
    It says 470uF 35w and is about 32mm length.
    Koshin (M) 85°C
    I measured with this device I have and I'm trying to understand if it's good or bad.,
  • petehall347
    • Jan 2015
    • 4425
    • United Kingdom
    Re: Is this cap good or bad
    the uf looks rather high so most likely needs a new one .
      Bad cap, it is showing the reading of 3401uF for the 470uF cap.
        • 30952
        it's very bad, when you get huge capacitance readings it means the cap is internally shorting and causing the tester to pump more power into it during the test - as you can see in the VLOSS figure.
        a polymer cap can be as high as 2.5%, some electrolytics as high as 1.5%.
        anything more is bad.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          supposed to be 470uF but reading 3401uF? definitely bad.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I thought 'lytics were/are generally spec'd at 20% tolerance? Do tell.
            sigpic
            (Insert witty quote here)
              BTW, Did you try checking other capacitors to see if it shows correct value using your meter.
              is this KOSHIN Electrolytics cap? What series?
              https://cdn.badcaps-static.com/pdfs/...6c7cb31823.pdf
                I believe STJ is referring to the VLOSS (D.F. - Dissipation Factor or Tan).
                VLOSS of 13% = to D.F. of 0.13
                For example of Panasonic FR series has D.F. from 0.09 ~ 0.22
                  • 30952
                  tolerance means the capacitance can vary by 20% over it's temperature range,
                  3401 is not within 20% of 470
                  you liberals always miss-understand tolerance!
                  • powrslave
                    • Jun 2020
                    • 6
                    • usa
                    Thanks for your support everyone.
                    I did replace it. Also this bad one was slightly bulging.
                    They combined series for this one in the chart. When I look for 470 35v the size isn't there but it's below. 15x31.5mm
                    I will ask in a separate thread for help or if there is virtual services offered.
                      • 30952
                      85' temp caps are general purpose, the ESR is never given for them.
                      and the ripple current(the amount the cap can store and release) cant be tested on small testers.
