I need to somehow bypass BQ24737 to work normal. it have ADP and ACOK pins. does anybody know their operating states/voltages/?
how to bypass BQ24737
Re: how to bypass BQ24737
What do you mean by "bypass"? Charger IC is required to charge battery and control MOSFET to switch between AC and battery power.
ACOK should be 0V on bq24737 when AC adapter is connected, there is no ADP pin.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by ktmmotocross View PostI need to somehow bypass BQ24737 to work normal. it have ADP and ACOK pins. does anybody know their operating states/voltages/?
You can use the bq24735 datasheet , for some resistive divider the value of resistors can change but hte result is the same you can check this readinta a schematic
or boardiview that contains this chipLast edited by jasko_jacker; 07-15-2020, 02:26 PM.
