Hi I have this circuit from a me welding station that has a burnt capacitor but I don't know the value of it wonder if you can help me? the one that is left has 100uf 50v there is a fuse on the circuit it is ok
MIG-130 feed motor PCB GI-PCB-H59-A0 repair (old: Help me with capacitor replacement)
Re: Help me with capacitors replacement
this might help a bit
https://www.reddit.com/r/PCB/comment...ng_components/
and this .. looks like its a bridge rectifier problem .. or something else killed it ..
https://www.reddit.com/r/AskElectron...m_overheating/
google lense seems to be getting better ..Last edited by petehall347; 08-12-2022, 05:40 PM.
it was a rectifier ..
looks like it needs redesigning to me . its that or needs quality parts .. bridge rectifiers arent fuses or even a good substitute , resistors however ......Last edited by petehall347; 08-12-2022, 06:06 PM.
I would say it's a crappy soft-start circuit, the big resistor gets bypassed by the triac once the main filter caps are charged up, after the delay.
The board does not look repairable - the bridge rectifier burned up quite badly and the board has too much carbon tracking for mains voltage use IMHO.
If the welder has shorted power components (mosfets, IGBT's) it usually burns up the soft-start resistor so not sure what happened here. The board might have had an arc across the connector/bridge rectifier due to badly designed pc board spacings.
What value of fuse is in the board? The diode 2W10M (2AMP/1KV) should be fine, If this is the wire feed motor drive circuit I would check the wire feed motor etc. for a problem, It may be that the wire feed stopped, and blew the fuse, then someone bypassed the fuse and the bridge and circuit traces burnt up.
Originally posted by R_J View PostWhat value of fuse is in the board? The diode 2W10M (2AMP/1KV) should be fine, If this is the wire feed motor drive circuit I would check the wire feed motor etc. for a problem, It may be that the wire feed stopped, and blew the fuse, then someone bypassed the fuse and the bridge and circuit traces burnt up.
Originally posted by bohaboha View Postthat's probably what has happened. i don't have this rectifier in my collection and would like to put it together as soon as possible. can you put a replacement one? Which one would you suggest?
Check the attached photo, the clearance is a joke!
I would put a regular bridge rectifier like I have shown if there is room for it.
Then remove the traces so the clearance between them is more than a cat whiskers hair!
But you need to triple check my work, it is hard to tell if there are more traces on the top of the board..."The one who says it cannot be done should never interrupt the one who is doing it."
Originally posted by Per Hansson View PostCheck the attached photo, the clearance is a joke!
Just noticed your board is unmarked but the one linked by petehall347 in reply #3 has markings on it.
The board is apparently for the wire feeder motor in the welder, and from what others wrote on Reddit it sags so the wire speed is inconsistent.
If you search for these you get lots of hits, seems like a remarkably crap design!
GI-PCB-H59-A0
ZD27223A0
PS: K1 is a: BT151-500R Thyristor (aka SCR)"The one who says it cannot be done should never interrupt the one who is doing it."
But you need to triple check my work, it is hard to tell if there are more traces on the top of the board...Last edited by bohaboha; 08-14-2022, 06:13 AM.
