HP ZBook 17 G2 bios dumps EC + MAIN needed!!!
    Re: hp ZBook 17 G2 Bios issue
    Originally posted by hoaca388 View Post
    Clean me file
    Hello and thanks for your effort.
    I took the above mentioned dump from hoaca388, and it works fine! Just installed windows successfully
      Re: HP ZBook 17 G2 bios dumps EC + MAIN needed!!!
      Same shit again, laptops shows only 5 blinks and then fan turns on at full speed.
      I will try to change the EEPROM now.
        can someone do a clean me?
        i got a problem with this model, when i do a clean me, the 15/20 second delay keeps apearing,
        tryed with flash image tool 9.1 and meinjector, both gives the same problem.
        hope someone can fix it
          Become a Badcaps supporter
          Thanks to all supporters.
            Originally posted by Vesko356 View Post
            thank you, vesko,
            but sadly still 15/20 second delay and a screen avout mud data recovery
              Hello there i have a zbook 17 g2 with la-b391p
              i lost original bios bin
              I don't know what is my me version
              And i don't know if i haven't dmi in bios .bin its bring failure or not ?
              I have only ec orginal .bin
              I tried some bois files but after some blinking led's its goes on high speed fan
              What should I do
              Appreciate for some help tnx
                What should I do
                You must post the laptop serial number
                https://www.badcaps.net/forum/troubl...ore-posting .
                  Tnx for reply and warning about the rules i appreciate that
                  so you telling me my problem is based on bios issues not other parts failure?
                    hi, I have an HP zbook 17 g2 la-b391p, I changed some wrong settings in the original bios but now the laptop stops at the HP logo and flashes 5 times caps lock. If I flash the EC or main with a dump I find here, does it work? Do the default settings return to me?
                    please help me. thank you
                    serial number is USH509L0HT
                    so should I dump bios or ec? thanks
                      here is the main bios of my laptop. Can someone clean it and restore default bios settings? I made the wrong settings and my laptop no longer starts and flashes 5 times. Thanks in advance to whoever will do it!
                      sn: USH509L0HT
                        sn: USH509L0HT
                        HP ZBook 17 G2 Mobile Workstation
                          HP ZBook 17 G2 bios
                          ineed fix mpm and WARNING!Machine is mot in committed state!
                          HP ZBook 17 G2
                          Serial: MXL5461CQ5
                          Product: G6Z43AVFG15
                          Warranty: 3y3y3y
                          The original bin is not available
                          I'm sorry, can you help me? I wrote via LCIIT MPM Unlock Tool, nothing changed
                            Try this https://www.badcaps.net/forum/troubl...70#post1252070
