Apple Macbook Pro A1278 BIOS Dump
    Re: Apple Macbook Pro A1278 BIOS Dump
    Originally posted by peste View Post
    try..
    hello,
    it works ..
    Thank you.
    How is it done to unlock the bios in a macbook.
      Originally posted by Usedcom View Post
      hello,
      it works ..
      Thank you.
      compare the two bios in the HxD program ...
        Hi, I need Bios Dump for A1278, 820-2936-B EMC-2419 Thank you!
          post the original bios
            I extracted this bin file from my EFI chip, Thank you!
              try..
                try..
                thank you Peste, I have a quick question. My MacBook is early 2011 I was forgot my bios password and ordered a new chip from Ebay I soldered on board, password cleared but I have a EFI sleep wakeup problem, fan spin very fast but won't turn ON, Sometimes I tried to reset the SMC but only 2 or 3 times was successful this method.
                I import your bin file into the Ebay's chip, but nothing happened. (Won't turn ON, Fan spin very fast)
                any Solution?
                Thanks,
                  any Solution?
                  Thanks,
                  Try
                    Originally posted by Ghamidi View Post
                    Try
                    Thanks Ghamidi, I imported new Bin file that you attached, It turned on I hope the sleep-wakeup problem is solved. I will work with it and update the result here.
                      A1278 2012 EFI LOCK
                      who can help me?
                      25L6406E
                      readed with asprogrammer, tnx
                        Originally posted by gsm4all View Post
                        A1278 2012 EFI LOCK
                        who can help me?
                        25L6406E
                        unlocked by yourself, thanks
                          Originally posted by ala_borbe View Post
                          if you have password problem, read bios with password and post it here
                          pls help me remove password.
                            try..
                              try..
                              thanks working for me.
                              godbless
                                hi
                                i have this dump from MacBook pro A1278 locked , i Need clear password thanks
                                  Originally posted by 24gsm View Post
                                  hi
                                  try,..
                                    try,..
                                    thanks its work
                                      Can you please remove bios password?
                                        Izvolte/Here you go.
                                        I don't provide help for people using CH341A and a clip.
                                          All right, buy a macbook pro a1278 but this one with Efi.
                                          take out 1 backup, someone can help me from some free backup to put it.
