HP Probook 450 G2 440 G2 LA-B181P BIOS + 470 G2
    Re: HP Probook 450 G2 440 G2 LA-B181P BIOS + 470 G2
    Update to my request:
    Got it to work. I had to clean up the me region of my bios dump. After that everything works as expected. Thanks to everyone.
      for all
      if bios M73 try this
      https://www.badcaps.net/forum/attach...1&d=1605787276
      (serial number DUPA000000 for edit hexeditor UTF-16 before flash)
      regards all
        Originally posted by peste View Post
        Hi
        your bin file was good
        .no error and booting quick performances
        thank you friend.....
          Hi
          ok time 15s
            I need a batch of hp 470 G2 i7-5500U, AMD Radeon R5 M255
              post the backup of the bios
                I don't have the original dump
                  I have a dump that works but the WARNING !! Machine is not in committed state!
                    try..
                      try..
                      Thank you. After typing and locking wndmifit, the WARNING !! Machine is not in committed state! Secureboot option in bios is not available. Administrator password unknown.
                        usually the message Machine is not in committed state! appears when the DMI information is missing..after you entered it, it remained in the bios ??? try to bring the security settings to the factory values ..
                          enter feature byte is blank, enter build id.
                          The rest is completed.
                          Second thing, in windows you can see the radeon tab, you can install the driver but there is an exclamation mark.
                            try entering the ID like this ....
                            https://www.youtube.com/watch?v=9T57ktw8n3Y
                            install the video chipset driver ...
                              Nothing can be done with the amd card. It still is
                              windows has stopped this device due to reported problems. (code 43). It is possible that it is damaged?
                              It would be possible to throw a dump bios where will it be turned off?
                              About
                              I'll try later
                                hey can someone help me ,i have the 470 g2 awith the m74 bios (dont have any old bios )
                                the Bios.bin worked fine but it showed no serial number and all that so i decided to try other bios and now nothing works only blink the charger few times .not even the old bios.bin from the post work again...HELP
                                  Update : i try the ne last from peste and charging led blink ,power led light up and keyboard led light up nothing else no spinning no pictture
                                    it should work for you too, you probably write the bios chip with errors .... what programmer do you use ??
                                      ch341a but i was using a other one but cant find it , this one not even show me when i write that its complete it just say down that it writed , if you have a better version would be nice if you send it here
                                        try this
                                        https://www.badcaps.net/forum/showpo...6&postcount=10
                                          just asking Peste , how much for repair the notebook ?`
