Wine Enthusiast wine cooler, no power. Model # 272 03 29
    I'm gonna take this thing apart very soon, gonna give it a a look over. Check for burn marks and bulged caps.
    I read to check for continuity throughout, I have a multimeter, what process should I follow? How can I check for bad fuses as well?
    Any info helps, I got this unit for free. Thanks to everyone here.
    Re: Wine Enthusiast wine cooler, no power. Model # 272 03 29
    Do a visual check on everything, take pictures and go from there.
      Look at these pictures please.
        In picture 1 or 3, upper left corner, check if you have around +12 volts between ground and OUT (red wire). You did check the fuse, correct?
          Plugged in?
          I'm not getting 12 V, I'm trying the rear solder connections is that ok?
            No how do I do that?
            I think that's good my multimeter beeps and shows. 0.04 ohms
            It wont allow me to take the fuse out so I tested it on the board
              The fuse seems to check good.
              Check if you have DC voltage on the input capacitors It will be around 160VDC. Be very carefull, this is the a/c line side of the power supply
                the fuse is soldered in, you can't take it just out. If the fuse measures a short, which it does, it's good. We have to figure out where the problem is, is it on the secondary (low voltage) side, or is there a problem on the primary (mains circuit). If you do poke around the primary side of the PSU while plugged in, be careful. After all this is 120VAC, after the rectifier into the main filter capacitor are 170VDC. If you measure DC voltages on the primary side, the negative lead of your DMM goes to the negative of the main filter capacitor. Working with DC voltages on the secondary, the negative lead of the DMM goes to the negative of the output capacitor or GND.
                  For the technical guys, there are hand drawn bits and pieces of the board's schematic on the Web. I did find this "roughly similar" schematic, at least to help understand the basics.
                  It looks like a half-bridge SMPS that is self-resonant (for start-up) and then the TL494 takes over and running off the Peltier module power afterwards.
                  Common for the small capacitors by the heatsink to fail, like C8 on power for the TL494 47uF 25V to VCC pin 12.
                  Wine Fridge Power Board similar longggg thread here: https://www.badcaps.net/forum/showthread.php?t=42346
                  edit: Power Supply board CD-110-C also used in Haier wine coolers.
                    What's the best way I can carry out these tasks safely? I have an esd wrist strap and esd gloves. It would be nice if I could test it on a table, but I guess I have to have it all plugged in to test?
                    You can probably tell I am a not up to speed on diagnosing electronics, the challenge is nice but I also want to learn.
                    What is the TL494, is that a CAP or PWM - is that the same thing as a transformer?
                    On the primary side you say be careful, so I will try to not touch anything, only with probes, yes?
                    Edit: C8 is a cap should I refer to c8 on that schematic or the c8 on my board? It says CD-110-D6
                    CD-220-D6
                      there is a ceramic capacitor almost between the 2 transformers - c17
                      it looks very dark!
                        TL494 is the larger of the 2 chips on the left
                          I'm going to have to do alot of reading, will I need an ESR meter?
                            it looks very dark!
                            So test this one? How should I, what reading am I looking for?
                              This long chip? I see C8, should I test TL494 or the SMPS?
                              Do I refer to the schematic for TL494 to test?
                              Will my multimeter cut the mustard? No ESR meter
                                What is difference between main filter capacitors and the output capacitor on secondary?
                                Do I need an ESR meter?
                                  There is an electrocution hazard when taking measurements off a live board that is flopping around.
                                  Check if you are OK with your experience level and the dangers of working on mains-powered equipment. A slip with a multimeter probe can be bad if something shorts or your hand is touching the fridge.
                                  Capacitor C17 and resistor R33 are the snubber network, they do make a lot of heat and see high stress, and the chinese always use cheap parts there. C17 looks like a dog. Maybe 1000pF 1kV. R33 is half cooked. Need a side pic.
                                  But their failure would just stress the main power transistors...
                                  With the power off, I would use a multimeter and test the power transistors T6, T7? the ones on the two small heatsinks possibly part number CDL13005.[/s]
                                  edit: OP shows they are D13007K.
                                  Note some transistor makes have an internal diode across C-E.
                                  edit: No internal C-E diode in D13007K.
                                    Should I be testing from the backside (green)side of the board? I can hardly get my probes into position for the caps. C17 wasnt reading anything , c8 is difficult to test. Should I worry about something blowing up if I use multimeter? I dont want to touch something the wrong way.
                                      C17 is like a whoopie cushion looking thing, 102 1-KV
                                      R33 is white maggot looking thing with a long pin coming off top?
                                      With the power unplugged or off? If plugged in, power isnt on. These?
                                      How the heck do I test T6,T7?
                                        What's this?
                                        It seems like there will be numerous components on this board that could be bad, we will not know until I test them. But I cannot say I know properly how to do that.
                                        If I look for new board, problem could come back because of cheap parts on board.
                                        I'm still determined
