when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    That's what I thought
    • Nish
      • Sep 2013
      • 124
      I donot know
      • Nish
        • Sep 2013
        • 124
        Originally posted by R_J
        So you think that just because you have 5 volts on ZD907 you should have 5 volts for to supply the main board? Have another look at the schematic.
        in post #50 you said:
        Where is this voltage coming from???????
        By the way, before I put it in, I had 5v at the C915A. Since you said to put resistor to measure. I want to verify what voltage at there. So I can see after I solder resistor.
        • R_J
          • 9535
          You must have poor solder connections somewhere because in one post you HAVE 5 volts standby on C915a, The next post you have NO votage, then in another post the voltage is going from .1~5 volts.
          • Nish
            • Sep 2013
            • 124
            I did not do anything but now I am reading 1.886v.
              • 12094
              • U.S.
              #66
              Simple test, unhook all connectors from powerboard, with just ac plugged in to powerboard, do you have standby voltage??
              • R_J
                • 9535
                Time to start over and work on the power supply out of the tv and get a stable standby AL+5V. Like I said many times, NOTHING works without a stable standby voltage as it not only supplies the main board it also provides the VCC for the rest of the power supply. And REMEMBER, the standby AL+5V uses CN2 pin 11 (or C951A) for output ground.
                The (5v) that you measured across ZD907 is provided internally by the ic. Ther will also be a vcc voltage provided by the ic. This vcc voltage is a small current and slowly charges C912. The ic will only charge C912 to around 6~8 volts. The ic will start to PULSE the drain pin and this will PULSE the transformer primary. When this pulsing happens, a voltage is induced in the secondaries of the transformer. This is where D906 comes into play. D906 charges C912 to ABOVE 12 volts to tell the ic to come out of standby and produce PULSES of longer duration.
                Once C912 has more than 12 volts (17 volts). you will also have voltage on the secondary C951A. This should be around 5 volts. This secondary 5 volts feeds down to PC901 pin1 and also IC951 (this is a reference regulator) This regulator controls the voltage on pin2 of PC901. When this circuit is working properly, it provides FEEDBACK causing the voltage across ZD907 to drop and regulate the circuit voltage.
                • Nish
                  • Sep 2013
                  • 124
                  No I don't have it.
                    • 12094
                    • U.S.
                    #69
                    Looks like r j has it step by step in post #67, see if C912 comes up to proper voltage.
                    • Nish
                      • Sep 2013
                      • 124
                      Thanks R_J. These are the voltage around the IC901
                      • R_J
                        • 9535
                        Lift one end of D903, this will eliminate any problems caused by ic902 circuit. Then make sure ZD951 is not shorted.
                        • Nish
                          • Sep 2013
                          • 124
                          I lift the one end of D903 Still same. No 5v. ZD951 = 0.213 in diode mode.
                          • R_J
                            • 9535
                            ZD951 seems low in diode mode, I would think it should be around .6xx
                            If the main board is not connected, you should be safe leaving ZD951 (6.2v zener) out of circuit for now and see if your 5volts comes up
                            • Nish
                              • Sep 2013
                              • 124
                              I removed ZD951 and test on diode mode, it reads 0.638. Now I have -0.030.
                              I measured D950 and D952 are reading 0.206 at diode mode. I am testing on my bench now
                              • R_J
                                • 9535
                                D950 and D951 are schottky diodes, they have a lower forward voltage drop so .206 is ok.
                                • Nish
                                  • Sep 2013
                                  • 124
                                  D950 and D951 are schottky diodes, they have a lower farward voltage drop so .206 is ok.
                                  Oh ok. Do you think the caps (C950 and C951)on that line give trouble? They are no polarity, how can I test in circuit?
                                  • R_J
                                    • 9535
                                    C9050/951 would only cause a problem if they both were shorted.
                                    As a test. Monitor for voltage across C951a and with the power supply pluged in, temporarly short PC901 pins 3 to 4 and see if you get any voltage across C951a
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      Still 0v
                                      • R_J
                                        • 9535
                                        I don't know what else to check, without a scope to see what the ic is doing. The ic should be pulsing the (internal mosfet) drain, that should be pulsing the primary and there should be some voltage on the secondary, if there is nothing at all I can only guess that the ic is defective.
                                        • Nish
                                          • Sep 2013
                                          • 124
                                          Thanks for helping me R_J. I will check if I have new IC and if I have I will replace and update you.
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
                                          • DriversScrew
                                            Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
                                            by DriversScrew
                                            Hello everybody,
                                            I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
                                            Vin: 5,0V
                                            Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
                                            Pin1: ? (perhaps enable)
                                            Pin2: GND
                                            Pin3: Vout - connected to 3ยต3 coil
                                            Pin4: Vin
                                            Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
                                            I searched many datasheets, but no one seemed to match according the surrounding components.
                                            Best similar parts I found were...
                                            12-21-2023, 07:06 AM
