Toshiba 50L7363D image issues (t-con?)
  • MeAndTheBoys
    • Jan 2020
    • 10
    Hi folks,
    I have a Toshiba 50L7363D on my workbench wich has image issues.
    I´ve not opened it so far (will do so tomorrow)
    Do you have a hint where I can start troubleshooting?
    I suspect t-con board?
    I have the equipment (at work) to replace smd chips and even BGA´s, so I`m aiming to avoid replacing whole (expensive) bords.
    Thanks in advance!
    Ben
  • MeAndTheBoys
    • Jan 2020
    • 10
    Re: Toshiba 50L7363D image issues (t-con?)
    Originally posted by MeAndTheBoys
    Hi folks,
    Thanks in advance!
    Ben
    Update:
    Reseated all ribbon cables, no improvement.
    T-con is a CHIMEI INNOLUX V420HK1-CS5
    Can anybody help me out with a clue? :-)
    • yokoono
      • Apr 2010
      • 479
      Check for starters that there are no backlight issues.
      • nomoresonys
        • 12096
        • U.S.
        One possibility: https://www.youtube.com/watch?v=H4sro4FMq18
        • MeAndTheBoys
          • Jan 2020
          • 10
          i checked that. I also have this wierd double Image, wich I suspect has nothing to do with backlight. The light is nice and even through the whole picture.
          • MeAndTheBoys
            • Jan 2020
            • 10
            Thanks, will check that tomorrow!
            • yokoono
              • Apr 2010
              • 479
              I thought this is the original image, not the double image. Hard to say. 50% t-con, 50% panel. Because it is cheaper the ideal would be to have a defective t-con.
              • nomoresonys
                • 12096
                • U.S.
                Maybe try the "cut tape" method: https://www.youtube.com/watch?v=j7vl7-vZEL8
                • MeAndTheBoys
                  • Jan 2020
                  • 10
                  tried cut tape - didnt work - wierd thing is when I disconnect the right side of the t.con the left side of the image becomes clear !
                  • MeAndTheBoys
                    • Jan 2020
                    • 10
                    Replaced tcon, same issue....
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      any damage/burnt parts on the lcd panel pcb
                      • MeAndTheBoys
                        • Jan 2020
                        • 10
                        By LCD panel PCB you mean the ones that are recieving data from the T-Con?
                        I found no burnt parts on any pcb...
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          there is a pcb thats bonded to the lcd panel sometimes we see damage on this pcb liquid shorted smd caps etc
                          • MeAndTheBoys
                            • Jan 2020
                            • 10
                            found no blown smd caps or liquid damage.
                            BUT
                            If i tape the 3 right contacts of the ribbon cable of the "bad" side of the panel I get a halfway decent image (see attachment)
                            One side of the image is still darker and slowly fades when changing the menu for example...
                            do you guys have any more tips? I´m ready to give up on this one...
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              The smd caps won't look blow, have you tested for a short ?
                              • MeAndTheBoys
                                • Jan 2020
                                • 10
                                just checked the caps on the lcd panel pcb. -> no shorts
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Bad panel. Last resort is to rip off the side tabs on the bad side.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    BUT
                                    The "tape mask off" method usually doesn't resolve issues on a panel that has side tabs IF the problem is with one of the side tab drivers. This is because the driver is still in the drive circuit for the panel and causing an issue which you are seeing. As suggested, the last resort is to removed the tabs from the "bad side". The result will likely be a good picture. This is assuming that the problem isn't with the bottom driver board on that side... such as a bad smd capacitor or connection to the panel in the bottom corner which is used to connect signals to the side tabs (ie. thru the panel edge).
                                    Based on my limited experience with a 46in sony, you will likely be successful with the tab removal (the sony had an issue with connection in the corner).
                                    • yokoono
                                      • Apr 2010
                                      • 479
                                      High resistance on VGH, VGL paths between t-con and side drivers.
                                      • nomoresonys
                                        • 12096
                                        • U.S.
                                        Well take it down to see the side tabs and look for damage or black or burnt looking cof (chip on film) etc. also see if any get hotter than the others, lots of times the problem is obvious once you get to the side tabs.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
